Acrosswind Response of Reinforced Concrete Chimneys
Author: C-M. Cheng and Ahsan Kareem | Size: 1.13 MB | Format: PDF | Quality: Scanner | Publisher: Elsevier Science Publishers | Year: 1992 | pages: 12
[Image: 47740818716049965346.jpg]
The acrosswind response of isolated reinfe~c~d concrete chimneys of circular
cross-section is studied using wind tunnel tests, full-scale measureme,~ts and
response predictions based on semi-empirical methods. Three chimneys with available
full-scale response observations were selected for this study to compare their
measured and predicted responses. The wind tunnel experiments involved measurements
of unsteady aerodynamic loads on rigid models of circular cross-section and
aeroelastic response of scale models of full-scale chimenys. Tests were conducted
initially on smooth surface models, which were repeated with artificially roughened
surface. Attachment of discrete two dimensional surface roughness helps to simulate
artificially flow field features past a cylinder that represent the characteristics of high
Reynolds number flows. Utilizing this roughness configuration permits response
prediction of chimneys in boundary layer wind tunnels with a good agreement with
the observed full-scale response.
a- Follow the Forum Rules.
[-] The following 9 users say Thank You to asim99 for this post:
  • blaze, 3fan, david-smith, kowheng, ykhackhack, terrorruban, zrilek, malc, Dell_Brett
Influence of Nonlinear SSI on the Seismic Response of Reinforced Concrete Multistory TAFATNEB 0 1,092 11-23-2013, 03:39 PM
Influence of Axial Stress on Shear Response of Reinforced Concrete Elements miquan 0 1,297 05-25-2012, 03:28 AM
Last Post: miquan
EFFECT OF COLUMN CAPACITY DESIGN ON EARTHQUAKE RESPONSE OF REINFORCED CONCRETE BUILD cve_jule 0 1,535 07-15-2011, 11:40 AM
Last Post: cve_jule
THERMAL RESPONSE OF REINFORCED CONCRETE STRUCTURES IN NUCLEAR POWER PLANTS ir_71 0 1,725 11-24-2010, 07:30 AM
