building a pool at a beach in the sea
Current time: 09-19-2018, 10:02 AM
Author: ernestrazak
Last Post: shadabg
Replies 3
Views 1426
[Problem] building a pool at a beach in the sea
hi guys, i have this small project to design for a pool at the beach in sea water. i would appreciate it if anyone can point me in the right direction.
best Regards
As per my awareness,
This topic has been discussed earlier on this forum.
You may refer to the following links for proper understanding :
I hope this will help you.
Still the forum is open to discuss, in case of further confusion or non-clarity.
[-] The following 2 users say Thank You to shadabg for this post:
  • ykhackhack, LiviuM
@ernestrazk
1- What is the size of the pool
2- depths
3- Make sure you use pile
4- Analyze the pool for bouyancy for its empty condition
5- Provide at least fc'=4000 psi concrete
6- Min. of 4 inches of clear cover
If you need more info, please post
[-] The following 2 users say Thank You to ykhackhack for this post:
  • LiviuM, shadabg
Proper care should be taken, while design the water retaining structures.
As per dear friend "ykhackhack", Pool should be designed for empty conditions, because in this case, there will not be any counter pressure acting. so Max tension will be consider.
Moody's chart should be used for determining the constant in designing for Water Retaining Structure.
[-] The following 1 user says Thank You to shadabg for this post:
  • ykhackhack
