Calibration of the Live Load Factor in LRFD Design Guidelines
Current time: 06-21-2018, 11:24 AM
Author: mahyarov
Last Post: mahyarov
Replies 0
Views 1061
Author: Kwon, Oh-Sung | Size: 1.83 MB | Format: PDF | Quality: Original preprint | Publisher: Missouri Department of Transportation | Year: 2010 | pages: 115
[Image: 05126160855116477061.png]
The Load and Resistant Factor Design (LRFD) approach is based on the concept of structural reliability. The approach is more rational than the former design approaches such as Load Factor Design or Allowable Stress Design. The LRFD Specification for Bridge Design has been developed through the 1990s and 2000s. In the development process, many factors were carefully calibrated such that a structure designed with LRFD can achieve a reliability index of 3.5 for a single bridge girder (probability of failure of about 2 in 10,000). As the initial development of the factors in the LRFD Specification was intended to be applied to the entire nation, state-specific traffic conditions or bridge configuration were not considered in the development process. In addition, due to lack of reliable truck weigh data in the early 1990s in the U.S., the truck weights from Ontario, Canada measured in the 1970s were used for the calibration. Hence, the reliability of bridges designed with the current LRFD specification needs to be evaluated based on the Missouri-specific data and the load factor needs to be re-calibrated for optimal design of bridges. The objective of the study presented in this report is to calibrate the live load factor in the Strength I Limit State in the AASHTO LRFD Bridge Design Specification. The calibration is based on the Missouri-specific data such as typical bridge configurations, traffic volume, and truck weights. The typical bridge configurations and the average daily truck traffic of the bridges in Missouri are identified from statistical analyses of 2007 National Bridge Inventory. The Weigh-In-Motion (WIM) data from 24 WIM stations in Missouri are used to simulate realistic truck loads. Updated material and geometric parameters are also used to update the resistance distributions. From this study, it was found that most representative bridges in Missouri have reliability indices higher than 3.5. For many bridges in rural areas with Average Daily Truck Traffic (ADTT) of 1,000 or less, the average reliability indices are higher than 5.0. This study proposes a table of calibration factors which can be applied to the current live load factor of 1.75. The calibration factor is developed as a function of ADTT such that bridge design practitioners can select a calibration factor considering the expected ADTTs of a bridge throughout its life span. Impact of the calibration factor on the up-front bridge construction cost is also presented.
[-] The following 8 users say Thank You to mahyarov for this post:
  • blaze, kowheng, gulilero, triance, mgdario, subin91, Nilupa, hoxuantu
LOAD AND RESISTANCE FACTOR DESIGN By Theodore V. Galambos Hengki 3 2,731 06-27-2014, 01:10 AM
Last Post: inge911
Simplified Live Load Distribution Factor Equations mahyarov 0 1,135 10-24-2012, 06:32 AM
Last Post: mahyarov
