STAAD Foundation Advanced V8i Version 6.2 - Trial Version
Current time: 01-18-2018, 08:50 AM
Author: kardels
Last Post: er.shyams
Replies 4
Views 8332
STAAD Foundation Advanced V8i (06.02.00.11) - TRIAL VERSION
STAAD Foundation Advanced (Version 6.2) is just released. The release includes new options and enhancements of isolated and combined footings along with near complete ISM implementation. To honor many users requests, the program now supports 3 editions of ACI 318 code: 2005, 2008, and 2011. Another important enhancement is combined and octagonal footing detailed drawing which features auto scaled views, reinforcement with true thickness, sheet management, and more.
STAAD Foundation Advanced is a comprehensive foundation design program which offers the ability to model complex or simple footings, including those specific to Plant facilities such as octagonal footings supporting vertical vessels, strap beam foundations supporting horizontal vessels, ring foundations supporting tank structures, and drilled or driven pier foundations.
Common foundations such as isolated footings, combined footings, strip footings, pile caps, and mat foundations can also be designed for larger structures or using parametric wizards. It provides a streamlined workflow through its integration with STAAD.Pro and can also be used as a stand-alone program.
Click HERE for more info about the changes.
screenshot:
[Image: 69770351053773282786.png]
trial version (15 days)
IMPORTANT NOTICE:
You may use this software for evaluation purposes only. If you like it, it is strongly suggested you buy it to support the developers. By any means (if not license) you may not use this software to make money or use it for commercial purpose.
"Sometimes it is more noble to tell a small lie than to deliver a painful truth."
[-] The following 9 users say Thank You to kardels for this post:
  • mahyarov, zrilek, oanm2000, joker™, bigone, grgr, rendel_©, ranger, rezart
VIP can use struceng's solution for full version.
[Image: 16257288998340766537.jpg]
  • zrilek, ASEC, oanm2000, jakng
MIRROR>>STAAD Foundation Advanced V8i (06.02.00.11) - TRIAL VERSION
[-] The following 6 users say Thank You to cordoba123 for this post:
  • joker™, oanm2000, aslam, asim99, Rainbow, rezart
STAAD Foundation Advanced V8i (SELECTseries 3) 07.02.00.00
STAAD Foundation Advanced is a comprehensive foundation design program that offers the ability to model complex or simple footings, including those specific to Plant facilities such as octagonal footings supporting vertical vessels, strap beam foundations supporting horizontal vessels, ring foundations supporting tank structures, and drilled or driven pier foundations.Common foundations such as isolated footings, combined footings, strip footings, pile caps, and mat foundations can also be designed for larger structures or using parametric wizards. It provides a streamlined workflow through its integration with STAAD.Pro and can also be used as a stand-alone program.
Efficient design and documentation is realized through its plant-specific design tools, multiple design codes with U.S. and metric bar sizes, design optimization, and automatic drawing generation. The plant-specific tools include vertical vessel foundations (octagonal and square shape supported on soil or on piles), and heat exchanger foundations (combined, two isolated and two isolated with a grade beam), tank ringwall foundations, and driven or drilled pier foundations.Powerful modeling includes a physical modeling system, a toolkit mode, automatic pile arrangement, and FEM, which allows complex or simple layouts. The foundation toolkit mode was introduced to address the needs of special footing types like drilled pier and dead man anchor guy foundations.Productivity is increased through the ability to utilize the structural model with the foundation model through the integration with STAAD.Pro. Changes made in the STAAD.Pro model are tracked and can be merged automatically with the foundation model. View the integrated video.
STAAD Foundation Advanced is the structural engineers’ choice for foundation design of virtually any type.
[Image: 39195711292256320832.png]
  • PinkPant, er.shyams, raja, oanm2000, thanzawtun, bridgeengineer, ingenierobou, RyanRS, valjeanlk
Mirror link for the above
For Engineering and Beyond
[-] The following 10 users say Thank You to er.shyams for this post:
  • PinkPant, raja, oanm2000, thanzawtun, ting tsai huang, learner20, Williams, emmi, RyanRS, valjeanlk
Bentley Staad Foundation Advanced CONNECT Edition RajaK 1 2,405 01-16-2016, 11:51 AM
Last Post: Dell_Brett
RAM Structural System V8i Version: 14.05.04.00 marion33 5 7,774 07-22-2015, 07:32 PM
Bentley Geotechnical Software 2014 version 17.00.28.00 BennyP 2 4,810 04-18-2015, 01:37 AM
Last Post: fixxxer0
LEAP Bridge Enterprise (Version: 13.00.00.68 Date: 9/24/2013 FileSize: 244.5 MB) marion33 2 3,494 11-02-2014, 07:40 AM
Last Post: bigone
Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial) BennyP 4 8,228 09-09-2013, 06:23 AM
Last Post: pezhmankhan
