CEB/FIP manual of buckling and instability
Current time: 07-18-2018, 03:16 PM
Author: ir_71
Replies 2
Views 2017
Author: Comite euro-international du beton | Size: 1.8 MB | Format: DjVu | Quality: Scanner | Publisher: Construction Press Limited | Year: 1978 | pages: 135 | ISBN: 0904406865
[Image: 98109513716353064465.jpg]
The third volume in a series on concrete member design and technology is concerned with the stability of single columns and frames consisting of columns and beams for which design procedures are required. The following sections discuss design aspects in detail: (1) buckling limit state-fundamentals; (2) detailed procedures for columns; (3) particular problems; (4) frame analysis; and, (5) design of slender structures according to the model column method. Appendices cover the finite difference method of analysis; a computer program for the model column method; moment capacity tables and diagrams; and, coefficients defining the value and position of the parabola-rectangle compression diagram. /TRRL/
[-] The following 24 users say Thank You to ir_71 for this post:
  • malc, kowheng, mahyarov, jcbv, ssobhan, blaze, warbeast, Dell_Brett, mig21, foxxx2010, lisine, ruaumoko, zrilek, peixoto, ykhackhack, gulilero, Jackass, mgdario, seriousboy, oanm2000, monter, yanburak, MarcinX, paulocs
For your convenience, here is the PDF version of the djvu file posted by ir-71 above, high-quality, paginated and searchable.
[-] The following 18 users say Thank You to psppsp for this post:
  • warlord1, zrilek, majkyy, peixoto, kowheng, concreteok, oanm2000, eliseo.as, monter, simanta, cristi, MarcinX, knrsa, jcbv, blaze, subin91, chairatpk, sodapas
[-] The following 8 users say Thank You to ir_71 for this post:
  • Hengki, Dell_Brett, marion33, ssobhan, oanm2000, vardan, chairatpk, bridgeengineer
