Underground Box Structure as a Foundation for Shear Walls in Seismic Resistant Bldgs.
Current time: 10-22-2018, 01:13 PM
Author: GROUT
Last Post: usman
Replies 1
Views 1744
Underground Box Structure as a Foundation for Shear Walls in Seismic Resistant BuildingsWink
This kind of foundation can be an alternative solution for direct foundations.It solves the problem where oversized ordinary raft foundations are needed. In fact, the box foundation gathers the gravity loads resting on the peripheral walls, so that the global soil reaction reduces its eccentricity. In most cases the elements constituting the box structure,such as peripheral walls, raft, and ground floors, are already part of any actual building; they only need a proper seismic design, which is herein proposed. A simplified theoretical approach is presented to allow a correct proportioning and design of each structural element, such as reinforcing ribs and panels constituting the box.
Amendment:
Boxing structure must not have a expansion or seismic joint , Please read together with Article Interaction-Based Design Formulas for Transfer Beams:Box Foundation analogy.
link:
[-] The following 5 users say Thank You to GROUT for this post:
  • hatkam, RazvanMelek, oanm2000, andersen3, blaze
[Image: 02370043208609288031.jpg]
[-] The following 9 users say Thank You to usman for this post:
  • malc, kowheng, gulilero, tang1942, civilphongvan, RazvanMelek, oanm2000, ruaumoko, zrilek
Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 1,088 03-16-2016, 10:41 AM
Soil-Structure Interaction of Retaining Walls under Earthquake Loads TAFATNEB 0 1,773 12-26-2014, 11:12 PM
Constructing Seismic Resistant Masonry Houses in Indonesia RyanRS 0 1,082 07-19-2014, 05:44 AM
Last Post: RyanRS
SEISMIC ANALYSIS OF RETAINING WALLS WITHIN PLASTICITY FRAMEWORK TAFATNEB 0 931 04-27-2014, 08:35 AM
PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 1,417 04-11-2014, 10:13 AM
