Autodesk Quantity Takeoff 2013
[Image: 98664733672611681378.png]
Autodesk Quantity Takeoff: Building material cost estimate software. Cost Estimating & Quantity Surveying Software. Autodesk® Quantity Takeoff building cost estimating software helps make material costing faster, easier, and more accurate. Cost estimators can create synchronized, comprehensive project views that combine important information from building information modeling (BIM) tools such as Revit® Architecture, Revit® Structure, and Revit® MEP software together with geometry, images, and data from other tools. Automatically or manually measure areas and count building components, export to Microsoft® Excel®, and publish to DWF™ format.
•Takeoff in minutes automatically—Perform a takeoff on an entire building information model (BIM) in just minutes through integration of 2D and 3D design data.
•Greater flexibility than typical databases or spreadsheets—Perform interactive examination of 3D models for material cost estimating purposes.
•Dynamic counting—Count and quantify design data quickly and easily.
•More efficient manual takeoff—Supports the takeoff of JPG, TIF, PDF, and other “nonintelligent” image formats.
•Share, query, and clarify—Generate quantities linked to specific objects. Mark up and “round-trip” your comments.
•Faster and more insightful quantity reports—Create summaries and detailed quantity surveying reports quickly and easily.
[-] The following 11 users say Thank You to BennyP for this post:
  • Quantumm, 3fan, maad59, oanm2000, w64bit, Dell_Brett, zrilek, Andrew seah, Petrit, albert23rd, blaze
[-] The following 8 users say Thank You to BennyP for this post:
  • mahyarov, w64bit, zrilek, stosto6666, uetian19, Quantumm, 3fan, blaze
[-] The following 2 users say Thank You to melshy2711 for this post:
  • zrilek, killerbee
This was and remains a 32 bit application. Inside you can find Xforce KG for x64 and x32 but only the keygen for x32 will activate. I saw inside the same old setup files from the previous release (from April) and the only 64 bit application included is the DrawingViewer 2013 but the size to download is about 2 GB instead of 810 MB. If you want to install copy on the HD (when trying to install from DVD asks for the second disk).
Other links:
  • oanm2000, zrilek, Dell_Brett
Direct Link:
Autodesk 3ds Max 2013 (x86/x64) Mohammad6299 3 3,021 01-26-2016, 07:53 PM
Last Post: gotcha
Autodesk 2013 All Products Keygen For Win & Mac OS kirankumarklk 8 8,682 01-02-2014, 11:45 PM
Last Post: Petrit
Autodesk Simulation CFD 2013 (x86/x64) Mohammad6299 4 3,985 09-12-2013, 05:52 AM
Last Post: Mohammad6299
AUTODESK BUILDING DESIGN SUITE ULTIMATE 2013 BennyP 6 6,876 05-20-2013, 02:28 PM
Last Post: halil
Autodesk® Vasari 2013 Beta 2 KhaLed-S.E 0 3,690 05-07-2013, 12:33 PM
Last Post: KhaLed-S.E
