Autodesk Revit MEP 2010 SP1 x32/x64 (ENG - RUS)
[Image: 000f6114.jpeg]
Autodesk Revit MEP 2010 SP1 x32/x64 (ENG - RUS) | 1.8 GB
Autodesk Revit MEP - is a specialized solution for design and calculation of internal engineering systems, as well as the issuance of documentation on them. The program is based building information modeling (BIM). Autodesk Revit MEP helps to establish interaction between participants of the project team, resulting in a high consistency of documentation. With built-in calculation and the possibility of data exchange with third-party applications, the design is efficient and environmentally sound. CAD Autodesk Revit MEP available only as part of AutoCAD Revit MEP Suite.
System Requirements for 32-bit version of Revit MEP:
* Operating system Microsoft Windows XP Professional or Home edition (SP1 or SP2), or Microsoft ® Windows Vista 32 bit (SP1) Business, Home Premium or Ultimate edition (see the comparison versions of Windows Vista).
* Intel Pentium 4 processor with a clock speed of 1.4 GHz or equivalent AMD.
* 3 GB of RAM (1 GB if you do not want to visualization).
* 2.6 GB of free disk space.
* Monitor with 1280 x 1024 resolution and video adapter with 24-bit color depth.
* Browser Microsoft Internet Explorer 6.0 (SP1 or higher).
* Pointing device compatible with the Microsoft Mouse.
* To install: connect to the Internet or drive DVD.
System Requirements for 64-bit version of Revit MEP:
* Operating system Microsoft Windows XP Professional x64 Edition (SP1), or Microsoft Windows Vista 64 bit (SP1) Business, Home Premium or Ultimate edition (see the comparison versions of Windows Vista).
* 3 GB of RAM.
The list of improvements during the upgrade:
* When exporting to IFC is now applied level of detail associated with the current view.
* Increased stability of copying the geometry of the family to another family.
* Added functionality to ensure the mapping of gaps between the wires when you run the project without a template.
* Improved the creation of circuits on electrical devices containing multiple electrical connectors.
* Fixed the breaking of the chains, as well as their recalculation while maintaining the repository.
* Improve capacity to change the basis for the elements based on the faces.
* Brand Callout premises are now designated categories of stamps premises suitable for the management of species.
* Now you can use the line separator walls when the walls of the grouping of related architectural models.
* Fixed display control panel settings in diameter.
* An issue related to the removal of the load factor in the performance of the Undo command after making changes in the load factor.
* Fixed memory leak when printing or publishing a 64-bit versions of the OS.
* Corrected the value of unit viscosity of air, the default parameters in the mechanical equipment.
* Improved the stability of work when you add a connector pipe to the family with imported CAD geometry.
* Fixed graphic pipes with lifting / lowering in one line on the cut.
* Now you can change the type of pipeline equipment for insertion of families with only one connector.
* Fixed display of geometry on fragments of the plans.
* Fixed disconnection fittings when changing type knee air duct, located close to the transition pipe.
* Fixed the mistake of turning protrusion fitting airway when you change the width of the main duct.
* Now the options are offered as a trace in choosing the air duct, designated system, and the choice of indefinite duct.
* Increased stability of the air while trying to build the project without levels.
* In some cases, when using the fill color ducts wrongly displayed in one line. This was fixed.
* Increased stability of alignment with the air ducts on the cut.
* Fixed extraneous graphics, which sometimes appear on fitting air ducts.
* When creating a connection from the cell to the main duct for the branch duct added airflow.
* An issue which consisted in the fact that when you move the main duct with the arrow keys moved to the branch duct.
* An issue which consists of the connection with taps at equalizing ducts.
* In some situations, inclined tube with a presentation in one line does not appear. This was fixed.
* On the subject of MEP, located below the lower boundary of the main hewer range, now used type of lines provided for objects outside the range.
* Increased stability of the choice of equipment in the partially set up a system of air circulation.
* Now when tracing duct or pipe section to automatically set the alignment in the middle / center.
* When you work with tools a path linking small displacement are now displayed in yellow, indicating a possible failure of the layout in case of adoption of the trajectory. In this case, choose another option to change the trajectory or the trajectory of hand.
* Improved geometry, and exported in the form of gbXml in the analysis of energy consumption, in particular by removing excess cutouts and small narrow space.
* When importing into Autodesk Green Building Studio ® models, which is given the metric system of measurement, now displayed metric units of measurement.
* Increased stability of the callouts when editing a family of brands functional zones.
* Increased stability of the editing nested families.
* Foundations of buildings are now correctly exported to the format gbXML as overlapping, but not as a wall.
* In the dialog box, heating and cooling loads, beside official spaces now displays icons for office spaces.
* Increased stability of deleting the values of the phase of the electrical distribution system.
* When you click constructing air duct in the context menu form and size of the new duct is automatically set in accordance with the selected duct.
* Fixed updating of the full load on the panel power when changing the type of electrical device to another type of load.
* On the tape an instrument of separation facilities added tools to choose the ribs, the form lines, etc.
Improvements platform Autodesk Revit:
* Dragging panel strip near the type no longer causes a pan of this type.
* Improved color shading in the output file when exporting to a format DWFx.
* With mirror project reflects all parts, sections and elevations, which have references.
* With the active sheet in the form of teams tapes correctly displays the status of the user interface.
* For reference points available instance property "Contact".
* In the print preview is now possible to call commands using keyboard shortcuts.
* Increased stability of printing.
* Now maintained path to the image decals.
* For instruments already added to the Quick Access Toolbar is disabled "Add to Quick Access Toolbar.
* When you plotting species on the control panel no longer shows the kinds of old and new state teams.
* Improved icons for level of detail on the control panel types.
* Improved procedures for creating and editing forms of formative elements for conceptual design.
* Enhanced separation surfaces formative elements for conceptual design.
* Improved graphics performance when working with species cube (ViewCube).
* Fixed bugs when you preview images before printing and printing images.
* Increased stability of the printing in a PDF.
* For types created with the command "Copy type, updated the image in the select list of types.
* The list of selection types to be added to the Quick Access Toolbar, remains on this panel when you open a new session Autodesk Revit MEP.
* If there is more contextual tabs, when you click on the Options bar displays suitable contextual tab.
* Increased stability of the presence of several open sessions Autodesk Revit MEP.
* On the options panel no longer displays duplicate icons from the tape and the scope of the application window.
* Increased stability of the printing and export.
* Fixed error when entering the special text characters with a combination of Alt and number keys.
* Improved conditions for displaying the tape.
* After re-opening of the project in terms of correctly displayed in the image format TIFF.
* Now the function to release all objects when you close the local file works if the project contains a new species, a family or working set.
* Operation selection border while creating a ramp or stairs now does not recall the command "Run."
* In the editor families "component detail, now provides controls that are intended for treatment.
* In the file from the application ADSK Autodesk Inventor now in Autodesk Revit MEP not lost information about the PUK.
* Frame size the application window remains open for the next session.
* Among families are shortcuts to invoke the command "Show hidden elements" and the team selection.
* There are a keyboard shortcut to select the previous object.
* When you export raster images into a format DWF ™ applies the given parameters of quality.
* The Quick Access Toolbar command synchronization with the repository is now located next to "Save".
* Improved visual selection tabs in the mode of fine lines.
* Changed icons for commands relevant to the sections and elevations.
* Now at the drop-down list, make room area "," Column "," Make marks "and" Component / sequence of nodes / Component legends "on the tape indicated the team caused by the latter.
* Improved accuracy of the parameters in the families using the directory types.
* Improved display of shadows.
* Improved export process in the IFC.
* Improved display of color fills in the forms of facades.
* Performing the correct choice of the value of the alpha channel of the sky when exporting to TIFF or PNG.
* Improved process of building walls on the edges of imported formative elements.
* Fixed display of outer contours of walls on the types of nodes.
* When exporting compounds in the walls of DWG file with the general coordinates of all the collinear lines are now combined into one.
* Increased stability of the compounds with the switch erasures parallel walls, described in technical note on the working characteristics of Revit.
Improvements to the API in Autodesk Revit:
* During the transaction in the formation of geometric objects using the API for the formative elements are no longer displayed on the message Revit inaccuracies.
* Property NumMembers LinearArray object associated with the parameter of the family.
* Fixed linking FamilyParameter with the property Label objects BaseArray and Dimension.
* Includes tools for updating the reference path to RevitAPI.dll for samples.
* Updated sample DistanceToPanels.
* Improved the stability of work in creating NewReferencePoint with PointOnEdge with the reference to ModelCurve.
* The transition from managed code to unmanaged code no longer causes a discharge of floating point values.
* In the API for printing ViewSheetSetting.Save () removes all types of users no longer causes an exception InvalidOperationException.
* Using the wrong values in sketchPlane NewSweep (SketchPlane) now leads to a notable exception.
* Now you can assign a value to ElementId through FamilyManager.Set.
* Improved stability of using the event DocumentOpened and related files.
* Increased stability of VSTA.Autodesk, AutoCAD, Autodesk Inventor, DWF, DWG, Green Building Studio, Inventor, Revit, and
ViewCube are registered trademarks or trademarks.
Additional information: For general systems, x32/x64 installation files, so they are in the general archives of both the Russian version, and for the English version
Download Links:
Autodesk Revit MEP 2010 x32/x64 " Templates & Libraries "
* After downloading the following files, you may need to update the file locations manually (on the Application Menu, click the Options button, press the File Locations tab to review and modify the location of your files). For Microsoft® Windows® XP, the default location for templates and family content is C:\Documents and Settings\All Users\Application Data\Autodesk\RME 2010. For Microsoft® Windows Vista®, the default location for templates and family content is C:\ProgramData\Autodesk\RME 2010.
* In an office with multiple computers running Autodesk® Revit® MEP software, you may want to install these files to a location on your network.
* To open these .cab files and extract the content, use WinZip 7 or higher.
Download Links:
Kamran via HP :)
[-] The following 5 users say Thank You to kamran for this post:
  • timosi™, timosi™, mmat, StaadEng, danndiamond
Link mirror Mediafire (Autodesk Revit MEP 2010 SP1 x32/x64 (ENG - RUS))
Link is never die, and if it have password, it was:
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 3 users say Thank You to timosi™ for this post:
  • kamran, kamran, StaadEng
AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 3,991 04-21-2018, 10:51 PM
Last Post: joker™
Autodesk Revit 2016 (x64) BennyP 1 3,321 10-19-2017, 10:10 PM
Last Post: joker™
AUTODESK REVIT MEP V2014-ISO (x32/x64) BennyP 1 1,767 10-15-2017, 02:33 PM
Last Post: joker™
AUTODESK REVIT ARCHITECTURE V2014-ISO (x32/x64) BennyP 1 2,328 10-15-2017, 02:31 PM
Last Post: joker™
Autodesk REVIT 2018 LT BennyP 3 2,004 10-11-2017, 08:38 PM
