Autodesk Robot Structural Analyses PRO 2009
[Image: attachment.php?aid=19]
Autodesk® Robot™ Structural Analysis Professional software provides a scalable, country-specific analysis solution for the structural engineer to analyze many types of structures, including buildings, bridges, civil, and specialty structures.
Autodesk Robot Structural Analysis Professional calculates a wide variety of structures with a comprehensive collection of design codes, delivering results in minutes, not hours. This structural engineering software is versatile enough for simple structural frame analysis or complex finite element analysis and offers seamless interoperability with Autodesk companion products as well as an open application programming interface (API).
Key Features
Structural analysis features include advanced auto-meshing and modeling capabilities, fast dynamic solvers, and integrated reinforced concrete design and structural steel design modules.
Structural Analysis Software Comparison
The Autodesk structural design analysis solution is also available as Autodesk® Robot™ Structural Analysis software. Compare the two versions.
LINK:
pass for attached keygen:
.rar   keygen.rar (Size: 81.2 KB / Downloads: 126)
.jpg   Untitled.jpg (Size: 13.9 KB / Downloads: 2,004)
>> First learn from cracked software than be licensed1 <<
[-] The following 12 users say Thank You to cod-X for this post:
  • oanm2000, oanm2000, JCMAS, JCMAS, Panjack39, Panjack39, slim, slim, dfense, dfense, zrilek, zrilek
(01-23-2009, 01:02 AM)JIM1975 Wrote: The links are not working
I found this links:
RAPIDSHARE
EASYSHARE
Both links are interchangable;)
[-] The following 2 users say Thank You to Administrator for this post:
  • deltalead, deltalead
If the links doesn't work, you can download the trial version from here, and use the keygen.
Only complete the form, good look. :)
Follow the Rules
(02-21-2009, 08:13 AM)amaranu Wrote: hi,
I am not able to download keygen, if I click on attachments only attachments.php file is downloading and not zip OR Rar file. Kindly tell us how to download the keygen file.
test here:
Password:
[-] The following 11 users say Thank You to Administrator for this post:
  • CARLOS, CARLOS, oanm2000, oanm2000, ojancano, ojancano, amaranu, amaranu, yacinesoft, yacinesoft, Mhasan
Read the instruction first
1. Unpack.
2. Install. Choose stand-alone license and use whatever you want for serial (like 123-45678901 or 888-88888888, etc.).
Restart your computer after install the software
3. After install and restart, when you run app select activate it.
4. Run the keygen and apply patch (it is patching some ECDSA stuff in memory, no files are changed, so it is IMPORTANT that you apply this patch at this moment!).
5. Make activation code for your request code using the keygen.
and
Voilá
it's done
I didn't indicate that instructions I wrote was taken directly from embrace.nfo inside keygen file...
Sorry Embrace team for the omission and Thanks a lot for your work, wherever you are...
I followed instruction step by step and everything is working. I ran two examples from McKenzie's "Examples Structural Analysis" and results were Ok
Autodesk Robot Structural Analysis Professional 2019 joker™ 2 2,098 09-07-2018, 08:49 PM
Autodesk Robot Structural Analysis Professional 2018 rami1976 4 4,677 10-11-2017, 08:47 PM
Autodesk ImageModeler 2009 SP1 x86 build 19113 kamran 2 1,888 04-13-2017, 02:24 AM
Last Post: jose19356
Autodesk Robot Structural Analysis Professional 2017 x64 temp1366 2 4,122 05-02-2016, 09:08 AM
Last Post: temp1366
Autodesk Robot Structural Analysis Professional 2016 x64 BennyP 8 7,382 02-04-2016, 08:03 PM
Last Post: ibg0203
