Autodesk Raster Design 2013 (x32/x64) Trial
Current time: 07-21-2018, 01:00 AM
Author: BennyP
Replies 0
Views 2155
[Image: 95648849073215390790.gif]
[Image: 65823781364646708025.gif]
AutoCAD Raster Design allows you to effectively use scanned paper drawings, aerial photographs, digital elevation models (DEM) and satellite data inside your AutoCAD® drawings. You can insert bitonal, grayscale, and color raster images into your AutoCAD drawings, then correlate, edit, analyze, and export the results.
AutoCAD Raster Design can analyze and display image data from a wide range of sources, including satellite imagery, wavelet compressed images, and digital elevation models (DEM). AutoCAD Raster Design also provides efficient tools for cleaning up and archiving paper-based drawings in digital form.
  • Dell_Brett, cordoba123, oanm2000, joker™, XXXX123
Autodesk Inventor Pro 2019 Trial BennyP 1 447 05-21-2018, 03:42 PM
Autodesk Nastran 2019 Trial BennyP 1 611 05-10-2018, 02:54 PM
Autodesk AutoCAD Raster Design 2019 BennyP 2 534 04-25-2018, 02:01 PM
Autodesk 3DS Max 2019 trial rami1976 0 414 04-03-2018, 01:37 PM
Autodesk Inventor LT 2019 Trial BennyP 0 356 04-01-2018, 06:31 AM
