Earthquake Analysis in Ansys
Current time: 07-21-2018, 01:01 AM
Author: jamildear4u
Last Post: Mohammad6299
Replies 2
Views 2583
Earthquake analyses in Ansys
Size: 822 KB | Format: PDF | Quality: Original preprint | pages: 14
[Image: 45109345894855150895.jpg]
Do you want to perform earthquake analyses according to design codes or just in order to verify your structure? The current article describes in great detail two different approaches; the static (response specter) and the transient approach
Earthquake analyses can be performed by applying different procedures. The most popular procedure is the Response Spectrum analysis (RS-analysis). The RS-analysis is cheap to use in terms of numerical costs as it is based on modal results. However, the spectrum solution can only show positive results, i.e. positive stresses and strains, as it only records the maximum amplitudes for each mode and the superposition of these results in turn will give the positive results.
Another procedure is to perform a full transient analysis of the earthquake. Such analyses are computational expensive. However, they will give results based on the dynamic equation of equilibrium and hence both positive (tensile) and negative (compressive) stress results will be reported for the full length of the earthquake. In this tutorial a shell structure will be used to show how such analysis can be run in ANSYS Workbench.
[-] The following 29 users say Thank You to jamildear4u for this post:
  • 3fan, Grunf, warbeast, blaze, ssobhan, seriousboy, terrorruban, slowet, jcbv, Rainbow, cace-01, Dell_Brett, zrilek, malc, medo_sk, Jackass, nhim4mat2006, ruaumoko, carolinandra, WPMT, highcivil, smail, igor1234, nickycruz, gundis, simanta, joker™, Nilupa, ykhackhack
links dead; new links
[-] The following 7 users say Thank You to andersen3 for this post:
  • ykhackhack, warbeast, viet2010, Dell_Brett, vardan, ting tsai huang, harsono
I think this webpage is the same as the PDF file:
ANSYS Tutorial: Earthquake analyses in workbench
[-] The following 5 users say Thank You to Mohammad6299 for this post:
  • malc, zrilek, Dell_Brett, draluka, melekeen
