Concrete: Shear Wall Design (BS8110)
Powerful spreadsheet to design shear walls under wind plus dead load combination. Essential for stability check of reinforced concrete structure. If you spend hours calculating wall stiffnesses, ∑(kr2) etc. for reinforcement areas and concrete stresses - then this spreadsheet will reduce your design time to as little as several minutes.
[Image: 82713538647986780959.jpg]
Direct Link:
.xls   1ABCD.xls (Size: 221.5 KB / Downloads: 316)
"If I had eight hours to chop down a tree, I'd spend six sharpening my ax. "- A. Lincoln
Just on comment:
Be careful with this worksheet as it doesn't take into account the full coupling of elements that constitute each core. What it does is to simply sum the stiffness of the individual rectangular elements as if they were separate. This may lead to severe errors in the analysis!
Take a look at Zalka's book (Global structural analysis of buildings) and you'll find a consistent and easy method to evaluate the global response of your building.
[-] The following 9 users say Thank You to avscorreia for this post:
  • Dell_Brett, malee, mowafi3m, student71, bigone, caifan, mohcivil, zrilek, malc
anyone can repost the link. Link seems to be dead or inactive.
Shear Wall ACI camto2 0 1,107 06-10-2018, 12:01 PM
Last Post: camto2
Shear Wall EC2/EC8 camto2 0 1,746 06-14-2017, 05:16 PM
Last Post: camto2
Analysis: Rigidity Determination for Shear Wall & Shear Wall with Opening Veggeta 3 4,722 05-09-2013, 02:23 AM
Last Post: odiclas
Masonry: Masonry Shear Wall Design per ACI530 - DTLi Veggeta 2 4,068 12-17-2010, 12:43 AM
Last Post: usman
Concrete: Shear Wall Design by JEC robertsas 2 3,646 12-08-2010, 01:38 AM
Last Post: usman
