Finite-Element Analysis of a Composite Frame under Large Lateral Cyclic Loading
Author: Feng Zhou1; Khalid M. Mosalam, M.ASCE2; and Masayoshi Nakashima, M.ASCE3 | Size: 312 KB | Format: PDF | Quality: Original preprint | Publisher: JOURNAL OF STRUCTURAL ENGINEERING © ASCE | Year: JULY 2007 | pages: 9
This paper presents finite-element FE modeling and nonlinear analysis of steel-concrete composite frames subjected to very
large cyclic loading. A three-dimensional FE model is developed to carry out the nonlinear analysis. Modeling details of the steel frame,
the reinforced concrete RC slab, the interactions between the RC slab and the frame beams, and the associated constitutive relationships
for cyclic loading are presented. A composite frame previously tested by the writers is analyzed using the proposed FE model. Good
correlation is observed between the experimental and analytical hysteresis curves up to rotation amplitude of 0.04 rad. One of the notable
observations during the loading to large rotations is the fracture at steel beam ends. To simulate such behavior, a simplified fractured steel
connection model is introduced. The proposed nonlinear model is found to be capable of capturing the fracture behavior of beam ends to
an acceptable accuracy.
[-] The following 6 users say Thank You to jamildear4u for this post:
  • kowheng, lisine, jcbv, Dell_Brett, malc, tluc
ConPrimer-2 Finite Element emmi 0 1,757 03-27-2015, 01:59 AM
Last Post: emmi
Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 2,021 10-21-2014, 09:57 AM
Last Post: Munykong
Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 1,117 03-31-2014, 11:46 PM
FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC TAFATNEB 0 1,344 03-31-2014, 11:22 PM
III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 1,308 03-31-2014, 11:11 PM
