| PocketStatics V2.01 Current time: 05-20-2012, 10:51 AM |
PocketStatics V2.01
02-06-2012, 11:54 PM
Post: #1
PocketStatics V2.01
PocketStatics 2.01 Size: 133 KB
![]() PocketStatics is a structural analysis program for the PocketPC. PocketStatics can be used to solve most statics problems including statically determinate and indeterminate trusses and frames with any number of elements and degrees of freedom. It is also useful to analyze simple columns, single or continuous beams or any other 2D frame or truss such as moment frames, braced frames, as well as buildings and bridges. PocketStatics comes in two editions, one for the PocketPC PDA's and one for computers running Windows. This makes it extremely useful for civil engineers, structural engineers, structural designers, site and construction engineers, site inspectors, students, instructors and others. It is ideal for use in meetings, at construction sites, and if your phone is PocketPC enabled, you can use it wherever you can take your phone. PocketStatics is very interactive, and simulates to a great degree working with an engineering pad and a pencil. Toolbars are very intuitive, and the structure can be simply sketched on the screen using the stylus. The program automatically computes and displays results whenever any changes are made to the structure. The user can select to view the deflected shape, reactions, moment diagram, shear diagram, or axial force. The user can apply concentrated forces and moments, as well as constant and linearly varying distributed loads along frame elements. Frame elements can be specified to have moment releases on one end or on both ends. Translational and rotational degrees of freedom can be individually fixed for each node. Common boundary conditions (pin, roller, fixity) can be easily assigned through toolbar buttons. The program displays the exact deformed shape and force diagrams (moment, shear, axial), and locates the point with maximum or minimum deformation or force. The value of the maximum deformation or force is also shown which makes it easy to obtain results very quickly. PocketStatics uses the finite element analysis method and was developed from the ground up for handheld devices which typically have less memory, slower processors, and less powerful displays than their desktop counterparts. Hence, it is very efficient and small in size, but it is extremely user-friendly and interactive unlike most structural analysis programs. It is also very powerful and fast. There is no limit to the problem size that you analyze, you can define an unlimited numbe of nodes, elements and loads. PocketStatics Features PocketStatics provides analysis features that allow the efficient analysis of almost any two-dimensional frame or truss. Whether you need to analyze a single beam or column, multiple continuous beams, or a complex frame or truss, PocketStatics provides the capability to perform that analysis. The user interface is very easy to use and very interactive and responsive which makes ideal for use in meetings, at construction sites, as well at your desk in addition to any other location. This allows you to quickly test ideas and document and analyze your structure whenever you want. Analysis Capabilities - Analysis of 2D frames and trusses - Element distributed loads. Can be trapezoidal (non-uniform) - Node loads (forces and moments) - Element releases - Define frame element properties (modulus of elasticity, area, moment of inertia) - Compute node deformations, reactions - Compute deformations, moments, shears, axial forces along element User Interface Features - Highly intuitive interface which allows you to use the Pocket PC stylus (PocketPC version) to easily and quickly sketch your structure - Interactive definition of structure geometry, boundary condition and loads without having to type any values - Further refinement of properties and load values can be easily accomplished using simple dialog boxes - Continuous analysis of the structure and display of results as you make modifications - Continuous feedback on the stability of the structure - Ability to show/hide: Nodes Node Labels Node Forces Node Moments Frame Elements Frame Labels Frame End Releases Frame Distributed Loads - Display of deformed shape, moment diagram, shear diagram, axial force diagram and reactions - Control values to be show on diagrams, you can refine how many values you see in order to optimize your view especially on smaller screens Private Note: [align=left] **************************Private Note: **************************No limits to creativity My body may be broken , but my spirit still fights on freedom |
The following 8 users say Thanks/Agree You to joker™ for this post:slowet, ssobhan, Dell_Brett, simanta, blaze, Josep Soroz, oanm2000, YaqubMughal |
02-17-2012, 02:46 PM
Post: #2
RE: PocketStatics V2.01
What's wrong with this? It's asking for the rest of the archives?
02-17-2012, 06:00 PM
Post: #3
The following 1 user says Thanks/Agree You to joker™ for this post:uetian19 |
User(s) browsing this thread: 1 Guest(s)
View a Printable Version
Send this Thread to a Friend
Subscribe to this thread
![[Image: 09508344543993492805.png]](http://pic.civilea.com/images/09508344543993492805.png)
![[-]](http://netdna.civilea.com/images/CivilEAV3.0/collapse.gif)
