Flux Core Arc Welding
Current time: 06-18-2018, 02:28 PM
Author: portal61
Last Post: portal61
Replies 0
Views 1335
[Image: 18972615511797914840.jpeg]
58 min | 640×480 | XviD 1018 Kbps | 29.97fps | Mp3 128Kbps | 481 MB
An introduction to the Flux Core Arc Welding process, covering both self shielded and gas shielded flux cored welding wires. This video focuses on fundamental welder skills. Extremely close-up video of actual welds, with detailed explanations, demonstrate how the voltage and wire speed settings, electrode extension, gun angle, and travel speed affect penetration, the shape, and the size of the weld. Also included are weld joints, metal preparation, and joint fit-up.
Flux Core Arc Welding also provides a working knowledge of constant voltage power sources, wire feed units, and the unique characteristics of flux cored welding wires. Understanding the technical aspects of FCAW is an important part of setting up the equipment to provide the correct amount of weld, with good penetration and weld fusion.
[-] The following 2 users say Thank You to portal61 for this post:
  • 3fan, thewhitesand
