STAAD Foundation V8i Select S4 05.03.00.32
Current time: 06-18-2018, 12:22 PM
Author: joker™
Last Post: joker™
Replies 5
Views 8458
[Image: 10384912422017892691.png]
STAAD Foundation is a comprehensive foundation design program that offers the ability to model complex or simple footings, including those specific to Plant facilities such as octagonal footings supporting vertical vessels, strap beam foundations supporting horizontal vessels, ring foundations supporting tank structures, and drilled or driven pier foundations.
Common foundations such as isolated footings, combined footings, strip footings, pile caps, and mat foundations can also be designed for larger structures or using parametric wizards. It provides a streamlined workflow through its integration with STAAD.Pro and can also be used as a stand-alone program.
Efficient design and documentation is realized through its plant-specific design tools, multiple design codes with U.S. and metric bar sizes, design optimization, and automatic drawing generation. The plant-specific tools include vertical vessel foundations (octagonal and square shape supported on soil or on piles), and heat exchanger foundations (combined, two isolated and two isolated with a grade beam), tank ringwall foundations, and driven or drilled pier foundations.
Powerful modeling includes a physical modeling system, a toolkit mode, automatic pile arrangement, and FEM, which allows complex or simple layouts. The foundation toolkit mode was introduced to address the needs of special footing types like drilled pier and dead man anchor guy foundations.
Productivity is increased through the ability to utilize the structural model with the foundation model through the integration with STAAD.Pro. Changes made in the STAAD.Pro model are tracked and can be merged automatically with the foundation model. View the integrated video.
No limits to creativity
Mirror
[-] The following 12 users say Thank You to joker™ for this post:
  • dshiva, Dell_Brett, maad59, barbong, oanm2000, Rainbow, rezart, zrilek, nektari0s, foxxx2010, Quantumm, NAUTILUS87
Mirror Install Files Post#1 & Post2
[-] The following 10 users say Thank You to joker™ for this post:
  • oanm2000, MOSS2000, Rainbow, Mouh@ndiss, rezart, zrilek, nektari0s, foxxx2010, Dell_Brett, NAUTILUS87
[-] The following 9 users say Thank You to joker™ for this post:
  • Mouh@ndiss, Dell_Brett, oanm2000, duazo2009, rezart, zrilek, foxxx2010, NAUTILUS87, piyush86
uncompress code is not working for your rar file.
Probably because the "TM" upper character is not reconized!
Moderator Note:
Use Copy/Paste (Control C --> Control V)
New Links
  • oanm2000, Milkshake, zrilek, narendra, MOSS2000, NAUTILUS87, malc, ranger, doguparthi, lednar_ved
STAAD Foundation Advanced CONNECT Edition 08.03.00.20 BennyP 0 816 02-11-2018, 06:31 PM
Bentley Staad Foundation Advanced CONNECT Edition RajaK 1 2,648 01-16-2016, 11:51 AM
Last Post: Dell_Brett
STAAD Foundation Advanced V8i (06.00.00.51) - New Release - TRIAL kardels 2 5,761 01-04-2012, 05:00 PM
STAAD.foundation V8i SELECTseries 2 (Release 5.1) BennyP 1 3,827 04-21-2010, 06:42 AM
Last Post: kardels
STAAD.foundation V8i Release 5.0 kardels 6 28,089 11-21-2009, 12:37 PM
Last Post: fiaz
