Bentley RAM Elements (SELECT Series 3) 12.05.00.12 + 12.05.01.18 update
Current time: 06-21-2018, 07:09 PM
Author: BennyP
Last Post: ykhackhack
Replies 5
Views 9642
Size: 329.56 + 56.24 MB
[Image: 86510753862874684181.gif]
This program provides unequaled flexibility for the design and analysis of different types of 2D or 3D structures containing linear members and shell elements.
The types of analysis available are: First order (Linear Analysis), Second order (P-Delta Analysis) and Dynamic (Seismic Analysis).
In addition, RAM Elements is also capable of designing hot-rolled or cold-formed steel members, wood (sawn lumber and glulam) and reinforced concrete members using the AISC 360-05 ASD, AISC 360-05 LRFD , BS 5950-00, AISI 01 ASD, AISI 01 LRFD, AS4100-98, NDS 05 ASD, ASD 05 LRFD, ACI 318-99, ACI 318-05 y BS8110-97 codes respectively. The program includes special modules for designing spread footings, combined footings, reinforced concrete columns, retaining walls, concrete walls, tilt-up walls, masonry walls, continuous beams and trusses. Additionally RAM Elements has links with RAM Connection, a revolutionary tool that allows the fast design of steel connections inside or outside RAM Elements, STAAD.Pro, the RAM Structural System and ProSteel (SDNF).
[align=left][Image: Download.png]
Mirror
OR
No limits to creativity
[-] The following 15 users say Thank You to joker™ for this post:
  • 3fan, Dell_Brett, valinhas, oanm2000, fretts08, 88FeNIX, ykhackhack, ali akbar, zrilek, blaze, simanta, pedzaquino, bigone, narendra, Nilupa
[-] The following 14 users say Thank You to joker™ for this post:
  • zrilek, oanm2000, Dell_Brett, valinhas, haze, ykhackhack, albani, pedzaquino, bigone, narendra, subin91, araza023, Nilupa, oreslaw
RAM Elements v12.5.2 Update
Update only
[-] The following 14 users say Thank You to tomdavar for this post:
  • zrilek, coxxxyboy, blaze, albani, ykhackhack, oanm2000, haze, benny, RICARDI, Dell_Brett, valinhas, joker™, bigone, Nilupa
Install Bentley RAM Elements (SELECT Series 3) 12.05.00.12
Update
[-] The following 8 users say Thank You to joker™ for this post:
  • oanm2000, haze, zrilek, bigone, Dell_Brett, araza023, Nilupa, valinhas
[-] The following 9 users say Thank You to ykhackhack for this post:
  • coxxxyboy, mahyarov, Dell_Brett, oanm2000, araza023, Nilupa, bigone, fefdbi, davegabj
Bentley SACS Connect V11 update 3 er.shyams 0 514 05-02-2018, 01:32 PM
Last Post: er.shyams
Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 8,867 09-25-2017, 07:25 PM
Last Post: Aviator
Bentley RAM Concept v06.02.00.014 Connect Edition Update 2 KhaLed-S.E 0 1,472 03-12-2017, 08:20 AM
Last Post: KhaLed-S.E
Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 4,838 09-28-2015, 09:38 PM
Last Post: joker™
Bentley WaterGEMS V8i (SELECT series 2) 08.11.02.31 BennyP 6 6,439 01-24-2013, 08:24 AM
Last Post: joker™
