Bentley RAM Connection V8i (SELECT Series 3) Release 7.0 + 7.3.1 upgrade
Size: 123.41 + 18.58 MB
[Image: 00096418938992744528.gif]
RAM Connection
This program provides unequaled flexibility for the design of different types of shear, moment, bracing and splice connections. It is based upon the provisions of the ANSI/AISC 360-05 for Steel Design Specifications and considers mainly W and HSS shapes.
You can call the program after RAM Structural System or RAM Elements and use automatically the results of the analysis and design of members.
The connection design can also be customized to adhere to your typical office standards.
RAM Connection Standalone
This software offers the best flexibility for the design of different shear, moment, braces, splices and base plates connection types. It is based on the AISC, ASD and LRFD codes, and the British Standard.
The standalone version works independently of any other software.
Users can create their own connections and fit them to the requirements of their company.
[align=left][Image: Download.png]
RAM Connection V8i 07.03.02.38 Update
[-] The following 10 users say Thank You to tomdavar for this post:
  • haze, joker™, ISTRAKTURA, Dell_Brett, dovsky, zrilek, oanm2000, mahyarov, blaze, Diquan
Mirror RAM Connection V8i 07.03.02.38 Update
No limits to creativity
[-] The following 10 users say Thank You to joker™ for this post:
  • eng donny, oanm2000, gacella, Dell_Brett, Andrew seah, valinhas, knrsa, mecheil.edwar, Diquan, narendra
Dear BennyP,
the link is dead now..
Link from Joker is not working properly..
Please give me a mirror and your advice..
@eng donny
I cheked the links and It is working.
[-] The following 1 user says Thank You to joker™ for this post:
  • mecheil.edwar
@ joker :
I have using crack from you, HWLockDLL.dll version is 14.0.0.1 (see my pic below)
and the result is not works..
[Image: 53699581810448149655.jpg]
But I try to using crack from RAM Advance 9 , HWLockDLL.dll version is 3.0.0.0 (see my pic below)
and the result is works but have some warning in first time and when I closed the software :
1. First Warning when I running :
[Image: 92560719932696631350.jpg]
2. The software running but I have no idea to check the result analysis.. :(
[Image: 25535141567811897181.jpg]
3.Second Warning when I closed the software :
[Image: 03943748675198152765.jpg]
Anyone could help with the correct crack/patch..?
[-] The following 1 user says Thank You to eng donny for this post:
  • mecheil.edwar
This is the struceng solution new link. Use the mandatory password.
[-] The following 14 users say Thank You to BennyP for this post:
  • eng donny, psppsp, Dell_Brett, zrilek, oanm2000, joker™, malc, mecheil.edwar, yutt, melvinsantos, ykhackhack, narendra, simanta, Clouseau
Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 9,300 09-25-2017, 07:25 PM
Last Post: Aviator
Bentley RAM Connection V8i SS6 10.00.00.129 rami1976 0 2,794 12-01-2015, 08:03 AM
Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 5,025 09-28-2015, 09:38 PM
Last Post: joker™
Bentley WaterGEMS V8i (SELECT series 2) 08.11.02.31 BennyP 6 6,677 01-24-2013, 08:24 AM
Last Post: joker™
RM Bridge (Select Series 3) v08.10.07.02 joker™ 2 6,085 12-23-2012, 05:28 AM
