Structural Shear Joints: Analyses, Properties And Design for Repeat Loading
Current time: 06-18-2018, 02:31 PM
Author: Dell_Brett
Last Post: Veggeta
Replies 3
Views 2502
Author: George T. Hahn, Kaushik A. Iyer, Carol A. Rubin | Size: 21,4 MB | Format: PDF | Publisher: Woodhead Publishing Limited | Year: 2005 | pages: 267 | ISBN: 0791802388
[Image: 78685904783957496876.jpg]
This book describes the mechanical response of butt, lap and doubler joints. The findings apply to shear connections in civil, aerospace, and other mechanical structures subjected to repeated loading. The findings are intended for engineers and NDE practitioners concerned with the design of new, as well as inspection and maintenance of existing shear joints. Fatigue strengths of the joints are derived using conventional, material S-N data and the joint stress concentration factor. Structural Shear Joints treats the different modes of load transmission: the bearing, clamped, and adhesive modes, joint geometry: fastener spacing and number of fastener rows, and fastener geometry: standard and countersunk heads and self-piercing and interference fasteners. It contains analyses that relate global features with the local conditions that govern contact fatigue damage such as the contact pressures, interface slips and the intensity and locations of stress concentrations. The role of fretting wear is discussed. The estimates of joint fatigue strength are compared with a selection of fatigue strength measurements for aluminum and steel joints. In many cases, the method offers valid estimates and preliminary designs of joints meeting given fatigue strength requirements. The book incorporates the results of over 150 recent and detailed, 2D and 3D finite element analyses of aluminum and steel connections. It includes handbook-type summaries of the results of the finite element calculations, as well as modeling details such as finite element meshes, material models, boundary conditions and validation procedures to assist design engineers with computations. A simplified methodology for modeling joints that contain adhesive is also provided. Useful for all engineers concerned with structural fatigue, the book addresses riveted and bolted joints, aluminum connections for airframes and automotive bodies, and steel connections for machines and bridges.
[-] The following 13 users say Thank You to Dell_Brett for this post:
  • cordoba123, blaze, melkat, Josep Soroz, jcbv, seriousboy, kowheng, stash, TAFATNEB, zrilek, fer962933, mohcivil, jonny78
Structural shear joints: Analysis, properties and design for repeated loading >> By G T Hahn, C A Rubin, Vanderbilt University and K A Iyer, US Army Research Centre, USA
Author: G T Hahn, C A Rubin, Vanderbilt University and K A Iyer, US Army Research Centre, USA | Size: 21.49 MB | Format: PDF | Publisher: Woodhead Publishing Limited | Year: December 2005 | pages: 238 | ISBN: ISBN 1 84569 119 9 ISBN-13: 978 1 84569 119 6
[Image: 05800998531684735627.jpg]
Add:
About the authors
George T Hahn (ScD, MIT, 1959) is Professor Emeritus of Mechanical Engineering and Materials Science at Vanderbilt University, Nashville, TN. Prior to that he was Manager of the Metal Science Section at Batelle Laboratories in Columbus, OH. He is a Fellow in the American Society of Metals and has published well over 150 papers in the fields of fracture mechanics, rolling contact, and riveted connections.
Carol A Rubin, PE (PhD, Kansas State University, 1966) is a Member, ASME, Applied Mechanics and Computers in Engineering Divisions. Dr. Rubin is Professor in the Department of Mechanical Engineering at Vanderbilt University. Her areas of expertise are finite element analysis and solid mechanics. She has published more than 80 papers in the areas of theoretical mechanics, numerical methods in applied mechanics, contact mechanics, and riveted connections.
Kaushik A Iyer (PhD, Vanderbilt University, 1997) is a Member, ASME, Design and Tribology Divisions. Dr Iyer is on the faculty of the Department of Mechanical Engineering at the University of Michigan. He works for the US Army Research Laboratory in Maryland. He has published nearly 20 papers on topics including riveted connections, contact fatigue, and quenching process modeling.
Contents
PART 1 MECHANICAL BEHAVIOR OF SHEAR JOINTS AND DESIGN CONSIDERATIONS
PART 2 COMPILATION OF FINITE ELEMENT RESULTS
Basic features
- Aspects of shear joints
- Out-of-plane deformation, microslip and plasticity
- Fasteners and the fastener load
- The bearing, clamping and adhesive modes of load transfer
- Stress descriptors for fatigue
Shear joints in the bearing mode
- Stress descriptors for bearing mode
- Butt joint
- Doubler
- Lap joint
- Lap joints in the bearing-plus-adhesive mode
- Multiple rows of fasteners
- Biaxial loading and effects of the free edge
- Fastener stresses
Clamping, interference, micro-slip and self-piercing rivets
- The clamped, fictional or slip-resistant mode of butt and lap joints
- Fasteners in the clamping mode
- Hole expansion, squeeze and interference
- Contact pressure, micro-slip and tangential stress
- Self-piercing rivet
Fatigue of shear joints
- Stages of the fatigue process
- Failure modes and locations
- Fatigue strength of panels
- Fatigue strength of fasteners
- Fretting wear and fatigue
Design considerations for repeated loading
- Mechanical performance
- Considerations for joint durability
- Joint type and mode selection
- NDI and fretting
- Fail safe design
- Generalizing finite element results
Load transfer in single rivet-row lap joints (conventional and countersunk)
- Summary of load transfer models
- Load transfer calculations for single rivet-row lap joints
- Summary and important points
Compilation of results for open hole panels and butt joints
- Summary of calculational models for open hole panels
- Summary of calculational models for butt joints
- Summary of calculational results for open hole panels
- Summary of calculational results for butt joints without interference
- Effects of interference in butt joints
Compilation of results for lap joints
- Summary of calculation results
- Summary of calculation results including interference and clamping
Single rivet-row lap joints under biaxial loading
- Summary of calculational models for 2-D and 3-D lap joints under biaxial loading
- Summary of calculation results for pinned connections under biaxial loading
- Summary of calculation results for single rivet-row lap joints under biaxial loading
Compilation of results for lap joints with sealants and adhesives
- Summary of calculational models for single rivet-row lap joints with sealants and adhesives
- Summary of calculation results for pinned connections with sealants and adhesives
Compilation of results for rivets
- Summary of calculational models for rivets
- Summary of calculational results for rivets
Data tabulations
- Summary calculation results for single rivet-row lap joints
- Summary calculation results for double rivet-row lap joints
- Summary calculation results for rivet installation residual stresses
- Summary calculation results for single rivet-row joints under biaxial loading
- Summary calculation results for single rivet-row joints with sealant
- Summary calculation results for variation of panel thickness in wide single rivet-row joints
- Summary calculation results for joint excess compliance and rivet tilt
PART 3 CALCULATIONAL MODELS AND VALIDATION
Finite element models
- 2D models of butt joints, attachment joints and open hole panels
- 3D models of single rivet-row lap and butt joints (standard and countersunk rivet heads)
Thin adhesive layer analysis (TALA) for modeling sealants and adhesives installed in joints
- Development of a thin adhesive layer analysis (TALA)
- Conversion of adhesive solid element to spring element for 2-D fem
- Conversion of stress-strain relationship to force-displacement relationship for thin adhesive layer
- Mechanical behavior of thin sealant layer
- Shear spring dependence of contact pressure
Material models for finite element calculations
Validation of finite element calculations and TALA
- Finite element model validation
- Validation of the thin adhesive layer analysis (TALA)
Stress concentration factors in multiple – row joints
- Analyses of multiple row joints
- Estimating fastener loads in multiple row joints
- Estimating fastener loads with 3D deformations
- A superposition method for estimating SCFs
- Validation
Analysis of fastener tension and clamping strain
- Nomenclature
- Clamping model
- Fastener tension and clamping strain predictions
- Summary of procedure
MirrorLinks:
Author: George T. Hahn, Kaushik A. Iyer, Carol A. Rubin | Size: 21.49 MB | Format: PDF | Quality: Unspecified | Year: 2005 | pages: 238
[-] The following 11 users say Thank You to TAFATNEB for this post:
  • jcbv, oanm2000, PinkPant, warlord1, Dell_Brett, subin91, mgdario, eliseo.as, jonny78, harsono, Aviator
[-] The following 7 users say Thank You to Veggeta for this post:
  • TAFATNEB, oanm2000, malc, PinkPant, Dell_Brett, jonny78, bridgeengineer
Structural Plasticity: Limit, Shakedown and Dynamic Plastic Analyses of Structures rusty 6 4,796 11-01-2014, 05:49 AM
Last Post: r3be1
Guide to Performing Effective Static and Dynamic Structural Analyses with MSC.NASTRAN zego2000 3 3,758 11-11-2013, 02:30 AM
Last Post: concreteok
