EdrawSoft Edraw Max Portable
Current time: 03-25-2018, 12:48 AM
Author: odiclas
Last Post: odiclas
Replies 0
Views 1375
‪EdrawSoft Edraw Max Portable‬
[Image: 38437932417851902127.jpg]
Edraw Max enables students, teachers and business professionals to reliably create and publish kinds of diagrams to represent any ideas. It's an all-in-one graphics software that makes it simple to create professional-looking flowcharts, organizational charts, network diagrams, business presentations, building plans, mind maps, fashion designs, UML diagrams, workflows, program structures, web design diagrams, electrical engineering diagrams, directional maps, database diagrams and more. With large pre-drawn libraries and more than 4600 vector symbols, drawing couldn't be easier! Edraw Max lets you create a wide range of diagrams using templates, shapes, and drawing tools while working in an intuitive and familiar Office-style environment.
EDraw Max is a vector-based diagramming application with rich examples and templates. Easy to create flow charts, organizational charts, business process, UML diagrams, work flows, program structures, network diagrams, chart and graphics, mind map, directional maps and database diagrams.
With pre-drawn libraries and more than 2000 vector symbols, drawing couldn't be easier! EDraw Max includes all the libraries and examples of EDraw product line.
EDraw Max is a new, rapid and powerful graphic design software, novel, small and exquisite, who works in the following fields:
· Flow Charts
· Organizational Charts
· Work Flows
· Software
· UML Diagrams
· Network Diagrams
· Business Process
· Charts & Graphics
· Directional Map
· Database Diagrams etc.
Here are some key features of "EDraw Max":
· EDraw is a vector-based diagramming software, which creates flowcharts, organizational chart and network rapidly.
· Support basic flowcharts, organizational charts, business charts, hr diagrams, work flows, software diagrams, UML diagrams, maps and network diagrams.
· Powerful and easy-to-use drawing tools and many pre-drawn library objects, drawing does not need to start anew. Just drag the ready-made shapes from the toolbar and drop them on your page. Drawing couldn't be easier!
· What You See Is What You Get. Zooming, scrolling, multi selection and multi-level undo/redo supported. No artistic skill is required. Automatically aligns and arranges everything to look great.
· Lots of shape templates. Offer more than 2000 shapes in common use, diagram drawing does not need to start anew.
· Gallery support. Offer the template storehouse to collect, manage various kinds of works of excellence.
· Distinct colors, fonts, shapes, styles, pictures, text and symbol for each object of the diagram are available.
· Common graphic format support and printing what your see is what you get.
· Easily visualize complex information with a wide range of EDraw diagrams. Make those diagrams even smarter and more useful by linking them to underlying data, which provides a more complete picture of the system or process.
New Features:
The UI is MS Office 2010 style like. Full ribbon features.
Added Themes, Color Themes, Effects and Fonts. Easy to change the whole diagram by changing the active theme. With the new Theme feature, you can format the colors and effects in an entire diagram with a single click.
Real-time previews. When you scroll over the various galleries in Edraw, you'll see your drawings and various objects change to display what they'll look like if you decide to apply those settings. Just click on the thumbnail in the gallery to actually accept the changes. This makes it a lot faster to see, for example, how changing a color scheme will affect your drawings.
Quick layouts and quick styles. These provide quick formatting options for the object in question, and make it easy to create good-looking slides with just a few clicks.
Put Edraw graphics into Word, Excel, PowerPoint with one-click buttons.
Text objects supported line space, bullet, Indent, back color, super script, sub script and more.
Shadows in general are so very nice compared to those in previous versions. We can actually control the transparency, amount of blur, and color now.
Shape and text presets make it really easy to apply a preset look to an object or text.
It's quicker to zoom in and out now using the zoom slider in the southeast corner of the screen.
Table support.
Recolor picture, Light and Contrast, transparent PNG support.
Opened the Shape Sheet for senior users to create more complicated shapes.
More 2000 clip arts.
Improved the Insert Hyperlink function.
Improved the Print function. Support more page sizes such as A0, A1. You can also print the large size graphics in separate pages.
Persistent undo and redo.
High quality graphic export.
Edraw Max is a vector-based diagramming software, which means whatever size you change the diagram, it will always keep high quality.
Easy and friendly UI
Edraw UI is MS Office-style like, it's easy to learn and use. If you are familiar with MS Office, you are familiar with Edraw quickly.
Work with MS Office well
Edraw provides several ways to cooperate with MS Office system.
You can copy the selected shapes then paste it into MS Office document.
You can insert the Edraw OLE object in MS Office application.
You also can export the drawings to generics graphic formats such as jpg, tif, bmp. Then switch to MS Office and insert the picture.
Support almost all kinds of graphics formats
Supports almost all the generics graphics formats, it can export or import those common graphics formats, like bmp, gif, dib, png, tif, wmf, emf, html and so on.
Save as exe file and share it with anyone without Edraw
You can save your drawing file to exe format and share it with anyone you want, even it has no Edraw installed.
Provide drawing tools like Illustrator
Provides a set of drawing tools like Adobe Illustrator, with those tools you can draw your own shapes or change the shapes in library.
Distribute shapes automatically
Edraw can help you align and arrange all shapes automatically, this will speed your working.
Strong style system and plenty of beautiful build-in styles
Edraw has an easy and quick style system, and provides a lot of pre-defined styles, which can help you make your diagram beautiful and personal in short time.
Abundant libraries and templates involving kinds of fields
Provide abundant libraries and templates include flowcharts, organizational charts, build plans, network diagrams and more.
Define and manage your own libraries and templates
You can draw your own shapes and documents save as libraries and templates, and use them as pre-defined libraries and templates.
Portable Version
[Image: homepage.png]
[Image: comments.png]
Only tested on Win XP
[-] The following 6 users say Thank You to odiclas for this post:
  • ska51, kvtasp, oanm2000, DamaD, dquan373, pulikesi23rd
Edraw Soft Edraw Max ML henrybill 0 1,581 08-31-2012, 12:01 PM
Last Post: henrybill
