Counterfort Retaining Wall Design
Current time: 07-23-2018, 07:05 AM
Author: 3fan
Last Post: hmwere
Replies 1
Views 6780
[Image: 77433148440259875175.jpg]
A retaining wall or retaining structure is used for maintaining the ground surfgaces at defrent elevations on either side of it. Whenever embankments are involed in construction ,retaining wall are usually necessary. In the construction of buildins having basements, retaining walls are mandatory. Similsrly in bridge work, the wing walls and abutments etc. are designed as retaining walls , to resist earth pressure along with superimposed loads. The material retained or supported by a retaining wall is called backfill lying above the horizontal plane at the elevation of the top of a wall is called the surcharge, and its inclination to horizontal is called the surcharge angle b
DIRECT LINKS thumbup
.xls   Counter+fort++Reatining+WAll.xls (Size: 571.5 KB / Downloads: 445)
Dear ALL,
If I may ask, Why are there so many "#REF!"s in the excel file. Any modifications required? Where should one start from in trying to rectify this file? Just in case, some one may upload the corrected version.
Thanks and regards
hmwere
[-] The following 3 users say Thank You to hmwere for this post:
  • TAFATNEB, albani, SCREAM7890
Excel Sheet for Concrete Retaining Wall-Metric rami1976 0 787 05-03-2018, 12:48 AM
Analysis: Retaining Wall Design RANA WASEEM 3 7,179 02-26-2018, 11:29 AM
Last Post: monter
Gabion Gravity Retaining Wall Dell_Brett 3 4,886 07-31-2017, 06:07 AM
Retaining wall Design rami1976 1 4,331 03-15-2017, 02:25 AM
Retaining Wall with Counterfort Check of Stability and Caculation of Internal forces bigone 1 5,509 04-09-2014, 06:23 AM
Last Post: bigone
