NCMA TEK Manual DWG Related Material
NCMA TEK MANUAL Drawings Material
Author: NCMA | Size: 8.4 MB | Format: DWG | Publisher: NCMA | Year: 2011
[Image: 54735970617166931535.jpg]
The National Concrete Masonry Association (NCMA), established in 1918, is the national trade association representing the concrete masonry industry. The Association is involved in a broad range of technical, research, marketing, government relations and communications activities.
NCMA is an association of producers of concrete masonry products, and suppliers of products and services related to the industry. NCMA offers a variety of technical services and design aids through publications, computer programs, slide presentations and technical training.
NCMA TEK MANUAL DWG DETAILS MATERIAL
Chapter 1 - General Design Considerations
Section 1A - Modular Layout of Masonry
Section 1B - Unit Properties and Specifications
Section 1D - Code Construction Tolerances
Section 1E - Code Detailing Requirements
Chapter 2 - Universal Detailing Requirements
Section 2A - Bond Patterns
Section 2B - Mortar Joints
Section 2C - Control Joints
Section 2D - Flashing and Weeps
Section 2E - Corners
Section 2F - Joint Reinforcement
Section 2G – Lintels
Chapter 3 - Single Wythe Construction
Section 3A - Above Grade Walls
Section 3B - Curtain Walls
Section 3C - Infill Walls
Section 3D - Prestressed Masonry
Section 3E - Foundation Walls
Chapter 4 - Multiwythe Construction
Section 4A - Noncomposite Walls
Section 4B - Composite Walls
Chapter 5 - Veneers
Section 5A - Steel Framing Backup
Section 5B - Wood Framing Backup
Section 5C - Concrete Masonry Backup
Chapter 6 - Anchorage and Connections
Section 6A - Wall to Roof
Section 6B - Wall to Floor
Section 6C - Wall to Wall
Chapter 7 - Reinforcement Details
Section 7A - Special Unit Shapes
Section 7B - Reinforcing Bar Positioners
Section 7C - Foundation Dowel Alignment
Section 7D - Corners
Section 7E - Reinforcement Intersections
Section 7F - Changing Reinforcement Location
Chapter 8 - Earthquake and Wind Details
Section 8A - Earthquake Details
Section 8B - High Wind Details
Chapter 9 - Specialized Details
Section 9A - Parapets
Section 9B - Columns
Section 9C - Radial Walls
Section 9D - Banding
Section 9E - Pilasters
Section 9F - Glass Unit Masonry
Section 9G - Fire Wall Construction
Section 9H - Sound Walls
Section 9I - Arches
Section 9J - Masonry Floor Systems
[Image: comments.png]
DWG FILES DOWNLOAD DATE JULY 2011
SITE:
CURRENT AS OF DATE
[-] The following 16 users say Thank You to malc for this post:
  • pedzaquino, knrsa, blaze, Dell_Brett, eliseo.as, lanz, haze, toa011, Jackass, duazo2009, ramla2002, cristi, Gkatzogias, bigone, lesgiu, spat
Author: NCMA | Size: 8.63 RAR MB | Format: DWG | Quality: Unspecified | Publisher: NCMA | Year: 2011
MIRROR TO POST # 1 DWG FILES FROM NCMA TEK MANUAL
BEST WISHES TO ALL
[-] The following 11 users say Thank You to malc for this post:
  • andersen3, uetian19, slowet, lednar_ved, blaze, cace-01, 3fan, maijuji, Ultra Zone, oanm2000, nan54
Author: NCMA | Size: 8.4 MB | Format: DWG | Quality: Unspecified | Publisher: NCMA | Year: 2011
The upload server hides some direct links to download servers please explore to find your favorite server
[-] The following 7 users say Thank You to malc for this post:
  • ykhackhack, Dell_Brett, vvvv, oanm2000, odiclas, scorpion07, sodapas
NCMA TEK Manual DWG Related Material UP TO DATE
Author: NCMA | Size: 15.3 MB | Format: DWG | Quality: Unspecified | Publisher: NCMA | Year: 2014 | pages: FILES
Up to date drawings material from TEK Manual as of July 2014
Section: 1A - Modular Layout of Masonry
Section: 1B - Unit Properties and Specifications
Section: 1D - Code Construction Tolerances
Section: 1E - Code Detailing Requirements
Section: 2A - Bond Patterns
Section: 2B - Mortar Joints
Section: 2C - Control Joints
Section: 2D - Flashing and Weeps
Section: 2E - Corners
Section: 2F - Joint Reinforcement
Section: 2G - Lintels
Section: 3A - Above Grade Walls
Section: 3B - Curtain Walls
Section: 3C - Infill Walls
Section: 3D - Prestressed Masonry
Section: 3E - Foundation Walls
Section: 4A - Noncomposite Walls
Section: 4B - Composite Walls
Chapter 5 - Veneers
Section: 5A - Steel Framing Backup
Section: 5B - Wood Framing Backup
Section: 5C - Concrete Masonry Backup
Section: 6A - Wall to Roof
Section: 6B - Wall to Floor
Section: 6C - Wall to Wall
Section: 7A - Special Unit Shapes
Section: 7B - Reinforcing Bar Positioners
Section: 7C - Foundation Dowel Alignment
Section: 7D - Corners
Section: 7E - Reinforcement Intersections
Section: 7F - Changing Reinforcement Location
Section: 8A - Earthquake Details
Section: 8B - High Wind Details
Section: 9A - Parapets
Section: 9B - Columns
Section: 9C - Radial Walls
Section: 9D - Banding
Section: 9E - Pilasters
Section: 9F - Glass Unit Masonry
Section: 9G - Fire Wall Construction
Section: 9H - Sound Walls
Section: 9I - Arches
Section: 9J - Masonry Floor Systems
Chapter 10 - Segmental Retaining Walls
Section: 10A - Construction Details
Section: 10B - Wall Drainage Details
Chapter 11 - Articulated Concrete Block
Section: 11A - Construction Details
Good luck Best Regards
DWG, DXF AND PDF FILES are present as in NCMA Open access site
[-] The following 10 users say Thank You to malc for this post:
  • ykhackhack, Mohammad6299, blaze, PinkPant, trmpereira, milova, melekeen, tooraj41, Dell_Brett, hendrik27
