COMPARISON OF NONLINEAR STATIC AND NONLINEAR DYNAMIC ANALYSES IN THE ESTIMATION OF TH
COMPARISON OF NONLINEAR STATIC AND NONLINEAR DYNAMIC ANALYSES IN THE ESTIMATION OF THE MAXIMUM DISPLACEMENT FOR STRUCTURES EQUIPPED WITH VARIOUS DAMPING DEVICES
Author: Payam Tehrani and Shahrokh Maalek | Size: 1.47 MB | Format: PDF | Publisher: 4th International Conference on Earthquake Engineering | Year: 2006 | pages: 10
[Image: 76656560139987459689.jpg]
Taipei, Taiwan
October 12-13, 2006
Paper No. 129
ABSTRACT
In this study, the nonlinear static (pushover) and nonlinear dynamic procedures in the determination
of maximum displacements of an existing steel structure retrofitted with different methods have been
compared. These methods include the use of the EBF systems; RC Shear Walls and the use of
Passive energy dissipators such as metallic, viscous, viscoelastic and friction dampers. In nonlinear
dynamic procedure, the response of the structure to seven scaled earthquake records has been
obtained and the average value of the responses is used for comparison. At the same time in nonlinear
static procedure, the maximum displacements of the structure in two different load distribution
patterns have been obtained. The results demonstrate that the nonlinear static procedure determines
the maximum displacement of the structure conservatively.
[-] The following 16 users say Thank You to cve_jule for this post:
  • Jackass, pingfan2, aslam, kowheng, oanm2000, Clouseau, blaze, jcbv, Ivan_1980, batata666, zrilek, malc, melkat, civilphongvan, tluc, neikrof
Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 5,835 08-01-2017, 10:19 AM
Last Post: abdulazizk
NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 1,875 11-15-2014, 03:07 PM
Loading Pattern and Spatial Distribution of Dynamic Wind Load and Comparison of Wind TAFATNEB 0 1,227 09-05-2014, 02:40 PM
Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 1,064 08-10-2014, 03:59 PM
Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 1,064 08-10-2014, 03:42 PM
