Autodesk Subscription 2012 MegaPack
[Image: 41883518153644726404.jpg]
Includes English and Russian
ArchVision RPC Content for AutoCAD Architecture 2012 and AutoCAD MEP 2012
AutoCAD 2012 ObjectARX Documentation & SDK
AutoCAD 2012 VBA Enabler
Autodesk MatchMover 2012
Autodesk Moldflow Adviser Design Plug-in for Inventor & Inventor LT 2012
Autodesk Moldflow Structural Alliance for Abaqus 2012
Autodesk Moldflow Structural Alliance for ANSYS 2012
Autodesk Revit DB Link 2012
Autodesk Revit Model Review 2012
Autodesk Subassembly Composer for AutoCAD Civil 3D 2011 & 2012
Autodesk Vault 2012 integration for Inventor LT Suite 2012 and AutoCAD LT 2012
Batch Print for Autodesk Revit 2012
Design Spreadsheets for Autodesk Robot Structural Analysis 2012
DIALux Plug-in for AutoCAD MEP 2012
Globe Link for Autodesk Revit 2012
Revit Extensions for Autodesk Revit Architecture 2012
Revit Extensions for Autodesk Revit MEP 2012
Revit Extensions for Autodesk Revit Structure 2012
Roombook Extension for Autodesk Revit Architecture 2012
Sample Industry Data for AutoCAD Map 3D 2012 and AutoCAD Map 3D Enterprise 2012
Space Naming Utility for Autodesk Revit MEP 2012
Worksharing Monitor for Autodesk Revit 2012
The link is for a torrent (from rutracker).
[-] The following 21 users say Thank You to BennyP for this post:
  • kowheng, jcbv, hazus, zrilek, chrono146, ArissB, ali akbar, freestar, haze, 88FeNIX, josephwsl, StaadEng, highcivil, Adam Smith, rezart, Ekkaia, oanm2000, XXXX123, Tensor, Filko, drewpt
Here is another links for Autodesk Subscription 2012 MegaPack
[-] The following 5 users say Thank You to thanzawtun for this post:
  • jcbv, zrilek, oanm2000, XXXX123, joinsms
Other Links: 3.2 GB
RAR(s) 9@330+244.4 MB
Enterupload
Filesonic
Fileserve
Cramit
Bufiles
[-] The following 9 users say Thank You to kowheng for this post:
  • zrilek, ArissB, 3fan, rezart, oanm2000, XXXX123, rkce, axcel, Dell_Brett
Other Links: Single RAR file, size 3.2 GB
For someone who has premium account.
[-] The following 15 users say Thank You to kowheng for this post:
  • ArissB, ali akbar, milvio, faros3000, zrilek, lisine, 3fan, rezart, nanescul, Ekkaia, allagui10, oanm2000, kmmh76, XXXX123, Dell_Brett
Other links (3.59 GB)
All links are InterChangable. It means you can download any part of the archive from any host, and can extract them without problem!
  • DamaD, oanm2000, zrilek, milvio, XXXX123, joinsms, axcel
Autodesk Subscription 2012 MegaPack (09.2011) | 6.18 GB
Contents :
FXHair 2012 for MAYA 2009-2012
Qualoth 2012 for MAYA 2009-2012
Cebas FinalDOF v1.5 For 3DsMax 2012
Cebas Thinking Particles R4.0 SP3 For 3SsMAX 2012
Xfrog 5 for Maya 2012
Archvision RPC Plugins
EdgeChEx 6.0.0 Max 2008-2012 32/64bit
XRayUnwrap v1.5.3 For 3DsMAX 2012 x32/x64
MultiScatter 1.1.08b For 3DsMax 2009 - 2012 32bit/64bit
SitniSati DreamScape Ver2.5F for 3DsMAX 2012 32Bit & 64Bit
Glu3D v1.3.36 & Pwrapper v1.016 for 3DsMax 2012 32Bit/64Bit
Batzal Roof Designer 1.4.6 3DsMax 2012 32Bit & 64Bit
Pulldownit Pro Ver 1.7 for MAYA 2009-2012 x32Bit & x64Bit
Phoenix FD 1.20.00 For Max 2012 32Bit / 64Bit
ORBAZ PFTBox #2 Pro v1.07 Box #3 Pro v1.531 3DsMAX 2012 x32/x64
The Setup Machine Ver 2.11 For Maya 2012, 2011, 2010, 2009 32Bit & 64Bit
Nvidia PhysX with APEX for 3ds Max 2011 64bit
Krakatoa 1.6.1.44739 for 3DS max
12d Data Extension for AutoCAD Civil 3D 2012
AutoCAD Civil 3D 2012 Import_Export Extension for GENIO
Autodesk Vault Professional 2012 Integration for Pro ENGINEER Wildfire
and more...
[-] The following 6 users say Thank You to BennyP for this post:
  • seriousboy, milvio, vccalderon, Filko, Dell_Brett, oanm2000
@BennyP part 1 error only the archvision rpc error. upload only that part 3.5 half gigs error
from the above links only the posts' #5 (except filesonic's) and the following links are working
i suggest the fileserve links for downloading cause the cramit link suddenly stops at 64% both times i've tried to download it
i' ve just download the above fileserve files. they don't contain:
i'm interested about the revit structure extensions. is it possible to upload them?
[-] The following 1 user says Thank You to rigid_joint for this post:
  • oasis_tree
can somebody please post the hotfile liink?
Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 1,519 03-03-2017, 12:05 PM
Last Post: bus001
Autodesk Products 2012 x-force keygen for x32 systems BennyP 5 8,252 02-03-2013, 01:20 PM
Last Post: KhaLed-S.E
Autodesk AutoCAD Plant3D 2012 (x86/x64) BennyP 6 4,710 01-17-2013, 06:47 PM
Autodesk AutoCAD LT 2012 x32 x64 ISO BennyP 12 8,172 12-17-2012, 04:32 PM
Autodesk AutoCAD Structural Detailing 2012 x32 x64 BennyP 18 16,613 03-01-2012, 03:19 PM
