Spreadsheet Calculator for RSA Pro 2012
[Image: 40349922865144265492.gif]
[Image: 63942899389676638198.gif]
Link by chrono146
Installed in Windows 7 32 bit and 64 bit.
Remember to use a 32 bit Excell (see my first post of RSA 2012).
When installed in 64bit with Office 2010 - Esop macro error.
Installed 32 bit Excell 2003 (for Wood need a update (office2003-KB907417-FullFile-ENU.exe) free from Microsoft.)
Now the excell works but something goes wrong with the licensing (adlm error 20) and the spreadsheet works only on demo mode.
In the 32 Windows 7 with RSA Pro 32 bit works without problems.
I installed in a fresh (from image) Windows 7 64 bit SP1 but maybe the licensing error reason is only in my system so please check.
A solution for using the spreadheet calculator in Windows 7 64bit.
This solution was discovered by vag1632 and he sent me a PM. It's like the apple of Newton story but works.
As i said Esop give a adlm error 20 and works in demo mode only.
Download from our forum or download the trial version from Autodesk site, Autodesk Quantity Takeoff 2012 and install.
You don't need to activate and you can delete the Quantity Takeoff directory from Program Files (x86)\Autodesk. The adlm works and the spreadsheet calculator too.
[-] The following 13 users say Thank You to BennyP for this post:
  • Mouh@ndiss, rezart, mowafi3m, milvio, Dell_Brett, oanm2000, handresy, zrilek, Milkshake, Clouseau, oreslaw, rigid_joint, albani
HotFile Mirror
rename file to "spreadsheetcalculator2012_content.exe"
No limits to creativity
[-] The following 8 users say Thank You to joker™ for this post:
  • Dell_Brett, 3fan, seriousboy, zrilek, oanm2000, ramla2002, albani, ykhackhack
try this:
Autodesk Spreadsheet Calculator 2013 for RSA Pro 2013 BennyP 2 4,907 11-29-2012, 06:58 AM
Last Post: jacky899
