Best Software for Blast Loading????
Good day Everyone,
If anyone have any idea about the Best Software for simulating BLAST LOADING on structures...
SAP or ETABS can't generate Blast Loading (dynamic) and its response,
No idea about STAAD.... Kindly tell me any software that do so....
Best Regards
[-] The following 1 user says Thank You to Umer.Aleem for this post:
  • mecheil.edwar
The problem is not with software..
I think the problem is how to understand the behaviour of Explsions to act as a real action on the Building...
If you read ASCE for petro chemical industries code... ASCE defines many types of explosions with different wave effects in behaviuor and intesity...
I did some projects and I used Sap ... By applying time History analysis...
I think Midas and Sap (also Etabs) will be the best software because you can study also the Plastic Behaviour of building during the Explosion (Blast Loading)
[-] The following 1 user says Thank You to mecheil.edwar for this post:
  • Umer.Aleem
Hello,
as long as I know, LS-DYNA is a software widely used to simulate blast loading. It is a Finite element program.
[-] The following 2 users say Thank You to Clouseau for this post:
  • Umer.Aleem, mecheil.edwar
conwep is right software for blast and easy
[-] The following 2 users say Thank You to ssamis for this post:
As long as the software can do time history analysis, we used it, we must know the effect of blasting in time history graphic format, please refer to Blasiting load book. Bu as I know
the best simulation figure for blasting loading case is ADINA
[-] The following 1 user says Thank You to usmanliang for this post:
  • Umer.Aleem
Any software that can do nonlinear time history will do the job. Blast loading has to be converted into time history forcing function that will act on the structure for a specific duration of time.
[-] The following 2 users say Thank You to ASEC for this post:
i prefer adina and ls-dyna which widely using in simulations via fem methods
[-] The following 1 user says Thank You to Gregory for this post:
  • Umer.Aleem
