SCI P343: Insulated Render Systems Used With Light Steel Framing
Author: C Wright, M T Gorgolewski, G H Couchman, R M Lawson | Size: 4.2 MB | Format: PDF | Publisher: SCI | Year: 2006 | pages: 53 | ISBN: 1859421652
[Image: 75538115854756766350.jpg]
This publication provides design guidance on the use of insulated render cladding systems as applied to light steel framing. Good practice recommendations and advice are given on choosing details appropriate to the degree of exposure to wind-driven rain. A performance scoring system is presented and the minimum requirements are based on the BRE exposure classifications of: sheltered, moderate, severe and very severe exposures. Details are given which provide ‘back-up’ or robust long term performance in the event of any water ingress or condensation behind the render layer. It is suggested that for ‘sheltered’ or ‘moderate’ exposure, a cavity behind the insulated layer is not required, but a double barrier or cavity or other back-up system is generally required for severe and very severe exposure conditions. Experience from the UK is presented to justify this approach.
[-] The following 13 users say Thank You to ir_71 for this post:
  • blaze, zrilek, Jackass, vvvv, kowheng, oanm2000, shaqee, seriousboy, malc, tluc, nhim4mat2006, warbeast, bigone
all links are dead; new link here:
[-] The following 2 users say Thank You to andersen3 for this post:
  • warbeast, slowet
SCI_P343 nsulated Render Systems Used With Light Steel Framing_2006-1859421652.pdf
have missing pages from 2-34
[-] The following 1 user says Thank You to bigone for this post:
  • Dell_Brett
Lightweight Steel Framing ir_71 2 2,958 11-13-2014, 06:08 AM
Last Post: ykhackhack
SCI P271: Case Studies on Modular Steel Framing ir_71 1 2,062 04-08-2013, 07:25 AM
Things You Need To Know About Light Gauge/Cold-Formed Steel Design goober 1 2,231 04-08-2013, 07:10 AM
Residential Hip Roof Framing Using Cold-Formed Steel Members ir_71 1 2,297 04-08-2013, 06:58 AM
Light-wood Framing in the U.S - Presentations Bmartin 0 1,619 12-20-2010, 03:21 PM
Last Post: Bmartin
