PERFORM 3D V5.0.0
PERFORM 3D V5.0.0 (installation only)
PERFORM 3D is a highly focused nonlinear software tool for earthquake resistant design. Complex structures, including those with intricate shear wall layouts, can be analyzed nonlinearly using a wide variety of deformation-based and strength-based limit states.
Model data can be imported directly from ETABS and SAP2000. A wide variety of element types are supported, including beams (with panel zones), columns, braces, shear walls (with openings), floor slabs, dampers, and isolators.
Nonlinear analyses can be static and/or dynamic, and can be run on the same model. Loads can be applied in any sequence, such as a dynamic earthquake load followed by a static pushover.
PERFORM 3D provides powerful performance based design capabilities, and can calculate demand/capacity (usage) ratios for all components and all limit states. Performance assessment based on ATC-40, FEMA-356 or ATC-440 is fully automated.
PERFORM 3D output includes usage ratio plots, pushover diagrams, energy balance displays, as well as mode shapes, deflected shapes, and time history records of displacements and forces
No limits to creativity
PERFORM 3D V5.0.0 FULL CD
I received this patch in my PM from Metto.
Using the License Generator your license will be for 365 days. This patch extends the license to 65535 days.
[Image: 34044561935211794126.gif]
[Image: 41375522219528100930.gif]
[Image: 75454537106017612286.gif]
Links:
RAR Password:
here u can find
[-] The following 8 users say Thank You to andersen3 for this post:
  • EngineerOO, civilgr, TAFATNEB, ykhackhack, ting tsai huang, moh_towhid, harsono, bigone
PERFORM 3D V5.0.0 FULL CD Without Med
[-] The following 11 users say Thank You to joker™ for this post:
  • zrilek, knrsa, Dell_Brett, oanm2000, EngineerOO, mohcivil, ykhackhack, constru10, ting tsai huang, bigone, Rami11
255MB iso file / Full CD - Medicine Included
0.35MB rar / Medicine Only
[-] The following 28 users say Thank You to lisine for this post:
  • isurya, cace-01, joker™, zrilek, malc, Petrit, oanm2000, EngineerOO, civilgr, david-smith, Dell_Brett, cesar, simanta, mohcivil, TAFATNEB, stash, marcel1983, psppsp, mgdario, mowafi3m, ykhackhack, RazvanMelek, Grunf, mohamz, blaze, ting tsai huang, bigone, Rami11
Portable CSI Perform-3D v5.0.0
[Image: 81668451505817500149.jpg]
[Image: 50299763409638904549.jpg]
Description:
- This is a complete, self-contained package using the Full Installation CD and the 'CSI License Generator 11' already featured in this thread.
- Made portable with Spoon Studio.
- Tested on Win7 and WinXP with .NET Framework 3.5 SP1 previously installed.
- Un-zip on PC and run from there, not from memory stick, for best performance.
NOTE: on PCs running McAfee virus protection, a warning of a “Generic Trojan” may occur for the downloaded file. This is a confirmed false positive. Simply add the portable program to the trusted applications.
[-] The following 15 users say Thank You to psppsp for this post:
  • milvio, kowheng, ykhackhack, blaze, malc, joker™, slowet, Dell_Brett, oanm2000, cordoba123, mohamz, subin91, sola4466, bigone, TAFATNEB
1 FILE (240 Mb)
[-] The following 2 users say Thank You to ykhackhack for this post:
  • Dell_Brett, bigone
Mirror Portable CSI Perform-3D v5.0.0
1 FILE 233.5 MB
[-] The following 9 users say Thank You to joker™ for this post:
  • ykhackhack, Dell_Brett, oanm2000, seriousboy, simanta, ptcruiser, mohamz, MOSS2000, bigone
Babak,
Please check one by one, some link stil OK.
From LISINE on Post # 6 :
[-] The following 3 users say Thank You to eng donny for this post:
  • ykhackhack, blaze, bigone
