ACI 318-08 Rec Sec. Mx -Q-Torsion Design_Rev04 Excel File
[Image: 74864536674158975836.png]
[Image: 90944097238646957353.png]
[Image: 91152673247352649386.png]
Excel file for Moment & Shear Strength(dirct sheer & Torsion) Design of Rectangular RC (beam or Slab) According ACI318M-08
[Image: homepage.png]
DIRECT LINKS thumbup
[Image: comments.png]
More Files & Design Guide in same 4shared folder
[-] The following 25 users say Thank You to bigone for this post:
  • Dell_Brett, vvvv, hmwere, Diquan, oanm2000, sasan7351, sodapas, jf28, dinu69in, Clouseau, faxel, salahcivil, leithowsky, mahfuzbangla, Jackass, malc, nhim4mat2006, araza023, ting tsai huang, ramla2002, YeiYei, rendel_©, u4406014, ykhackhack, manzoor_quadri
Moderators Note:
Thanks for the link, but you must pay the subscription to download the file. If you can not provide a link that allows a clean discharge, please not post such links ...
[-] The following 4 users say Thank You to bigone for this post:
  • Jackass, nhim4mat2006, chino1409, ykhackhack
ACI 318-08 Rec Sec. Mx -Q-Torsion Design_Rev05 Excel Sheet
[Image: 41462949336638052910.png]
[Image: 00609518292993334110.png]
[Image: info.png][/align]
***For Revision historysee Revision history sheet
Rev05
[-] The following 20 users say Thank You to bigone for this post:
  • kowheng, techno, 3fan, malc, Dell_Brett, araza023, gacella, dinu69in, oanm2000, blaze, rendel_©, cardinal85, tomtumx, HellboyRBJ, tluc, monter, sasan7351, falconado, portal61, ykhackhack
ACI_318-08_Rec_Sec._Mx_-Q-Torsion_Design_Rev06_02-May-2013.xlsx
[Image: 64209505997353818339.png]
[Image: 09022910178581284763.png]
REV 06:
1- adding row 66 which was removed by mistake in rev 05,this row show a message to change the cross-section for torsion,and have the following equation "=IF(D64<=G64,"Section Dimension is OK for tosion","Change Section Dimension for torsion")"
2- changing the text message in the following cells: G36, G37, G50, F61, B66
3-3- Rearranging the Stirrups claculation for shear and torsion, from row 69 to end
the outter stirrups supports the torsion + part of shear forces the inner stirrups supports the rest of shear force
4- changing the calculation of stirrups RFT. To be Av/S & At/S , to be easy to compared with Etabs Value in row 51, 53, 67, 68
[-] The following 18 users say Thank You to bigone for this post:
  • vvvv, adrian_p_2002, ykhackhack, Dell_Brett, smrutigandh.42, ruaumoko, kowheng, SCREAM7890, shadabg, MOSS2000, hignacio43, dinu69in, viet2010, Andrew seah, malc, draluka, techno, klsamy77
[-] The following 1 user says Thank You to bigone for this post:
  • MOSS2000
Moment & Shear Strength Design of Rectangular RC beam/slab According ACI318M‐08 Rev06
[-] The following 6 users say Thank You to bigone for this post:
  • SCREAM7890, melekeen, Dell_Brett, knrsa, ykhackhack, mohcivil
Moment & Shear Strength Design of Rectangular RC beam/slab According ACI318M‐08 Rev06.2 ,12-Apr-2014
[-] The following 11 users say Thank You to bigone for this post:
  • dinu69in, ting tsai huang, ykhackhack, malc, zrilek, Dell_Brett, harsono, ruaumoko, mohcivil, mgdario, simanta
ACI350-06 &ACI224R-01 Flexural Crack width Calculation for Rec RC sec Excel File bigone 0 4,789 09-07-2013, 12:20 PM
Last Post: bigone
