Autodesk AutoCAD Raster Design 2012 (x86/x64)
[Image: 50622163486887205014.gif]
[Image: 11950264129330359776.gif]
AutoCAD Raster Design - a program tracing images - enhances AutoCAD and software products based on it. AutoCAD Raster Design enables architects, engineers, design engineering systems and industrial designers to reduce time spent on perecherchivanie through the use of scanned drawings and plans received by software on the platform of AutoCAD.
AutoCAD Raster Design for use with AutoCAD, AutoCAD Architecture, AutoCAD Civil, AutoCAD Civil 3D, AutoCAD Electrical, AutoCAD Map 3D, AutoCAD Mechanical, AutoCAD MEP, AutoCAD P & ID and Autodesk Topobase to increase the value of project information.
AutoCAD Raster Design, used in conjunction with AutoCAD Map 3D, provides designers of engineering structures, transportation networks and the general plan, as well as cartographers and GIS specialists editing bitmap images, a visual analysis and processing of maps.
Key features
- Display Images on the screen. You can use a variety of graphics, embedded images, paste them into working drawings and export, as well as impose polygonal masks so that the screen could be seen only parts of images.
- Editing and erasure of images. The program has a team cleaning images of random points, displacement, mirroring and retouching.
- Manipulating bitmaps (REM). Standard AutoCAD commands can be used to control the raster fields and primitives. For example, this allows you to quickly erase the bitmap segments, arcs and circles.
- Means of tracing and optical character recognition. Tools vectorization, requiring minimal user effort, allow you to create segments and polylines on raster data. When converting the data can be used by the function of the optical character recognition.
- Transform pictures, map based geo-referencing and analysis. Features are supported when using the program in conjunction with AutoCAD Civil 3D, AutoCAD Map 3D and Autodesk Topobase.
(SN): 111-11111111
(KEY): 340D1
[-] The following 8 users say Thank You to BennyP for this post:
  • rezart, stldtls, Apache, zrilek, Adam Smith, Arshad, MJDENNIS, arspi
Other links:
  • zrilek, stepa, plngage
Other links:
  • zrilek, serhioSPA
Autodesk AutoCAD Raster Design 2019 BennyP 2 717 04-25-2018, 02:01 PM
Autodesk AutoCAD Raster Design 2018 BennyP 0 969 03-24-2017, 07:40 AM
AutoCAD Raster Design 2017 temp1366 1 1,054 03-28-2016, 07:37 PM
Autocad Raster Design 2016 (x64/x32) BennyP 0 1,756 03-20-2015, 09:43 AM
Autodesk AutoCAD v2010 x86 & x64 Eng (DVD-ISO) [NoPE]+AutoCAD Civil 3D 2009 kamran 1 2,757 04-20-2014, 08:31 PM
Last Post: cenlara
