Bentley CivilStorm V8i SELECT Series 2 08.11.02.65 (30 days trial and renew)
[Image: 95235608517672048846.gif]
Bentley CivilStorm V8i simulates your entire stormwater system within one intuitive scaled layout model for the MicroStation, Stand-Alone, or AutoCAD environments. The Bentley CivilStorm V8i dynamic stormwater modeling engine calculates runoff hydrographs and analyzes the hydraulic response through interdependent systems of inlets, pipes, channels, culverts, and ponds.
Bentley CivilStorm V8i helps you:
Avoid Costly Oversights
Stormwater components can dramatically impact each other. With Bentley CivilStorm V8i, you can quickly check for any domino effects between interdependent elements in the system to identify backwater storage effects and bottlenecks in the system that can result in costly unexpected flooding.
Visualize Dynamic Flooding
Bentley CivilStorm V8i provides a rich variety of presentation tools that make it easy for you and your clients to visualize flooding problems and how they can be eliminated. Animate profiles, plan views, and other presentations to observe water levels rising and falling over the course of a storm event.
Design Efficient Solutions
Bentley CivilStorm V8i provides "What if?" scenario management for pre- and post-development analysis, system rehabilitation, and other circumstances. Directly compare results for pre/post conditions or analyze the differences between design possibilities.
Bentley CivilStorm V8i features:
Dynamic integration of rainfall, runoff, surface flow, storm sewers, open channels, culverts, and ponds—in one model
True scaled layout environment, in a stand-alone environment or directly inside AutoCAD
Looped systems with diversions
Pressure and gravity profiles
Fast and stable computations
Infiltration and runoff
Unit hydrograph methods
Complex pond outlet structures
Capture and carryover between inlets
Hydraulic grade profile animations
Animated color mapping
Customizable presentations and graphs
Flexible management tools, from units to modeling options to a graphical environment
Tested in Windows 7 x64 using the crack posted in Lavteam by Istigatore. The registry patch transform the software to Trial Unlimited Size but after 30 days the trial expire. I added a file (BentNew.exe). Running it will restore the 30 days trial. And by the way it will restore the trial period for almost every Bentley trials posted here.
[-] The following 13 users say Thank You to BennyP for this post:
  • oanm2000, thanzawtun, josephwsl, malc, snakes, Dell_Brett, emmi, shezira, nuttapolk, Vanfa, ska51, vinnunsam, ginof0
Mirror Install File
I think your's IP is banned from Bentley (Your Location or Country)
No limits to creativity
[-] The following 1 user says Thank You to joker™ for this post:
  • ska51
Bentley Civilstorm V8i - Cumulative Patch Set for build 08.11.02.65
(Version: 08.11.02.65 Date: 10/17/201) 2.47 MB
  • ska51, caleno, jacs1976
(Version: 08.11.02.75 Date: 11/7/2011) 267.45 MB
  • fefdbi
Hi
Link
Password
Here the link
[-] The following 1 user says Thank You to saherboy for this post:
  • fefdbi
Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 9,300 09-25-2017, 07:25 PM
Last Post: Aviator
Bentley CivilStorm V8i SS5 08.11.05.113 ibg0203 0 1,562 02-23-2016, 03:56 PM
Last Post: ibg0203
Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 5,025 09-28-2015, 09:38 PM
Last Post: joker™
RAM Elements V8i (SELECTseries 4) 13.0.0.22 1000 days trial BennyP 9 14,245 08-23-2015, 07:24 AM
Last Post: ykhackhack
RAM Connection V8i (SELECTseries 4) 8.0.0.23 1000 days trial BennyP 12 24,187 08-18-2015, 10:00 AM
