Golden Software Grapher 8.7.844
Current time: 06-22-2018, 06:33 AM
Author: jcbv
Last Post: Grunf
Replies 2
Views 2740
[Image: 68814531056224147605.png]
An efficient and powerful graphing program for all of your most complex graphing needs. Ideal for scientists, engineers, and business professionals! Grapher is the ultimate technical graphing package available. This easy-to-use, powerful, and dynamic program will have you creating publication-quality graphs in minutes! The superior, professional, impressive graphs will be wowing your audience every time they see your graphs.
Create informative graphs with legends, magnifiers, and multiple plot types in the same graph!
Customize any portion of any graph to make the graph completely unique to your situation!
Create your own custom graphs by using the updated easy to follow Graph Wizard.
Add legends, curve fits, annotations, and drawing objects to complete the graph.
Organize your objects in the improved Object Manager and edit your graphs in the updated Property Inspector!
Create templates to use the same graph settings with multiple data files.
Save the graphs in Grapher 5, Grapher 6, or Grapher 7 GRF formats or Grapher 5, Grapher 6, or Grapher 7 GPJ formats to make sharing documents between colleagues easier than ever!
Automate the graphing process with the included Scripter™.
Record your graph making process with the Script Recording feature inside Grapher!
Export graphs for use in presentations and publications in one of Grapher's many export formats, including vector PDF, EMF, and EPS.
Create one of 54 unique graph types. There are four different types of 2D graphs that can be created in Grapher: linear, bar, polar, and specialty graph types. In addition, many of these graph types are available with a 3D aspect. If you need an extra variable plotted on your graph, try one of the 3D XYZ graphs, the contour maps, or surface maps!
[Image: homepage.png]
[-] The following 13 users say Thank You to jcbv for this post:
  • ska51, wanazri, milvio, engr1900, blaze, henrybill, tamboon, DamaD, Williams, mastermind, foogoo, 3fan, ting tsai huang
Serials for: Golden Software Grapher 8.7.844
note: the serial later serve as long as they v8.x.xxx
[-] The following 3 users say Thank You to henrybill for this post:
  • ska51, Williams, 3fan
As per Williams's and Ska51's request:
Uploaded: Feb/14/2011, File Size: 27.72 MB, RAR'd files
If you like this software, we strongly suggested you to buy it. Support the developers. By any means you may not use this software to make money or use it for commercial purpose! Use it only for evaluation!
[-] The following 6 users say Thank You to Grunf for this post:
  • melkat, jcbv, Williams, yamacdere, ska51, 3fan
Golden Software Grapher 9.4.819 serra 1 1,514 06-14-2012, 10:25 PM
Last Post: 3fan
