The Longbow Converter V3
Current time: 12-16-2018, 09:38 PM
Author: BennyP
Replies 0
Views 4664
Do you have one of the following issues with your AutoCAD:
•You have a new computer running 64bit Windows (Windows XP 64bit, Windows Vista 64bit or Windows 7 64bit), and you want to install your AutoCAD but it refuses to install with "This operating system is not supported by..." or "You cannot install this product on the current operating system." message?
•An old copy of AutoCAD that simply wont install or run on Windows 7/Vista?
•Maybe you have VBA code which runs very slowly on 64bit AutoCAD because VBA only runs out-of-process on 64bit Operating Systems? (VBA on 32bit AutoCAD runs in-process)
•You have ODBC functionality which doesn't work on 64bit AutoCAD or is very slow because Microsoft's ODBC drivers/Jet Engine drivers only support 32bit.
•You are using 3rd party AutoCAD plug-ins written in ObjectARX or .NET which can only run on 32bit AutoCAD?
•You can't use the Visual Studio 'Program Edit and Continue' feature when debugging 64bit AutoCAD
•You're finding that AutoCAD 64bit is slower than AutoCAD 32bit? That's because 64bit Windows are not automatically faster than their 32bit counterparts. In some cases, they may even perform slower because of the larger pointers as well unrelated OS overheads.
•Or if you just want to use the software that you already have...
...then The Longbow Converter will help you. It will update your installer media so that your 32bit AutoCAD will install and run normally on your 64bit Windows 7 or Windows Vista.
Works with...
•AutoCAD 2008, 2009 (All Languages) 2010, 2011 (English only)
•AutoCAD LT 2008, 2009 (All Langs) 2010, 2011 (English only)
•AutoCAD Map 3D 2009 (All Langs) 2010, 2011 (English only)
•AutoCAD Land Desktop (LDT) 2008, 2009 (All Langs)
•AutoCAD Architecture 2008, 2009 (All Langs) 2010, 2011 (English)
•AutoCAD Civil 3D 2008, 2009 (all langs), 2010, 2011 (English only)
•NEW! AutoCAD Mechanical 2008 (all langs), 2010, 2011 (English only)
•NEW! AutoCAD Civil 3D Land Desktop Companion
•NEW! AutoCAD MEP 2011 (English only)
•VBA Enabler 2010, 2011
•Support for R14*, 2000*, 2000i, 2002, 2004, 2005, 2006, 2007 also included!! See below!
New tools included with version V3!!
Old AutoCAD Installer Reviver and Old AutoCAD Program Reviver
Both override Windows 7/Vista restrictions so that your old AutoCAD will install and run properly on Windows 7 (and Windows Vista) 32bit and 64bit.
Works with...
•AutoCAD R14, 2000 (NOTE*:The Installer Reviver only works on 32bit Windows, however, the Program Reviver works for both 32bit and 64bit)
•AutoCAD 2000i, 2002
•AutoCAD 2004, 2005, 2006, 2007
It also supports other older programs that might be giving you trouble!
1 user license 39.99 U.S.D.
[Image: 65566585627782055344.gif]
[Image: 21674290673664235950.gif]
Home site
  • dovsky, Dell_Brett, jcbv, oanm2000, milvio, yucapareja, haze, Mouh@ndiss, 3fan
STDU Converter 2.0.61.0 [DJVU to PDF Converter] Dell_Brett 0 1,744 12-20-2010, 08:45 AM
Last Post: Dell_Brett
