Oil Storage Tank Design Calculation as per API 650
Current time: 06-22-2018, 12:34 AM
Author: duazo2009
Last Post: duazo2009
Replies 4
Views 5636
Oil Storage Tank Mechanical Design Calculation AS per API 650
[-] The following 23 users say Thank You to duazo2009 for this post:
  • faros3000, rohailiyaz, dinu69in, rezart, lednar_ved, Dell_Brett, malc, gatob, kowheng, rendel_©, blaze, tamboon, shaqee, mrgoodboydatdat, ramla2002, Nilupa, spat, zimmermannn, bigone, Yuma, Hengki, harsono, Finger7
Can you explain ... which software is used to come up with this design calculation, as it is just a computer output/printout
[-] The following 3 users say Thank You to usman for this post:
  • Yasir, duazo2009, TAFATNEB
This is a combination of manual and software calculation and analysis, the Software being used is Etank 2000 from E-ware
[-] The following 1 user says Thank You to duazo2009 for this post:
  • usman
(01-19-2011, 09:04 AM)duazo2009 Wrote: This is a combination of manual and software calculation and analysis, the Software being used is Etank 2000 from E-ware
Is the E-Tank give us the foundation loading data after mechanical design analysis?
Abdul Azeem
[-] The following 1 user says Thank You to mrgoodboydatdat for this post:
  • TAFATNEB
Yes, It will give you the foundation loading data depending on your input and it must be completely fill up depending on the required parameters.
Moderator Notes:
Please use "NEW REPLY" button or "Quick Reply" text editor at bottom next time. You may be warned for spamming if you kept replying with "REPLY" button (quoted text without good reason). Be careful, this is not the first time. You'll be warned for "SPAMMING", if you kept replying with quote text
[-] The following 2 users say Thank You to duazo2009 for this post:
  • mrgoodboydatdat, Umer.Aleem
