I can't view my post
I can't view my post in the following thread:
There should be a second reply - mine. Is it visible for the others? I can view it only by clicking 'last post'.
Yes, I can see it, don't worry, maybe you should try with other browser.
Engineering - the Art of Neglection
[-] The following 1 user says Thank You to rusty for this post:
  • datagap
Under the thread, I saw your reply as #3. I have replied as #4. It all should be up there.
By the way, I do not think you can reply to your own reply. You can add-modify or whatever, but the reply is reserved for others. Please correct me if my understanding is wrong.
[-] The following 1 user says Thank You to ravisbassi for this post:
  • datagap
Thank you very much! I'm calm now.
Maybe there is any bug. Here is a screenshot, so that moderators can see what I see. The third post (second reply) is missing. (In other thread I can view my posts. What is the problem? I use Mozilla Firefox 3.6.*)
[Image: 93160102223033336057.png]
I tried to view my post in IE 8, but the result is the same. The problem is not the browser. I suppose that the problem is in tthe option 'save draft'.
Initially I saved this post as draft. I edited it and posted. I hadn't used this option before, and there had been no problems.
Be cautious when using the option 'save as draft':
1. If you save as draft any formated text (e.g. via post generator), you will not be able to edit it and will lose it (this already has been reported as a bug)
2. If you save plain text, there is a risk to happens the same that has happened to me.
I can't find the thread reffered above. Obviously it has been deleted. (I can't imagine why)
But today I met the same problem in another thread containing my post. And I found a solution!
Normally, I view the posts in threded mode. Viewing in linear mode solves the problem!
I suppose this can help someone.
Many thanks to those who tried to help me!
Best regards
[-] The following 1 user says Thank You to datagap for this post:
  • concreteok
