Calculate beam and column strength
Current time: 06-20-2018, 10:27 AM
Author: ribak
Last Post: rigid_joint
Replies 5
Views 2930
I am looking for a software which can calculate the moment capacity of doubly reinforced concrete beam when concrete strength, steel strength, beam cross section, number of rebars and so on are given as input.
Also, with the similar input, I also want to calculate the interaction diagram of RC column so that the capacity of existing column can be determined.
Any software whcih can do sectional anaysis is able to calculate the moment capacities.
You can use Xtract, Response2000, Biax or other software or you can use some Excel spreadsheets.
[-] The following 1 user says Thank You to iceman84 for this post:
  • concreteok
You can find formulas for moment capacities of beam and columns in Fardis's book about EN1998-1 here:
[-] The following 6 users say Thank You to ivanveliki for this post:
  • Dell_Brett, ruaumoko, duazo2009, Yasir, concreteok, jaks
Dear ribak
If you do your design based on ACI Code :
1) If you want develop your own excel sheet, Mac Gregor book is a good reference to read
This book is useful both for student level & engineer level
2) If you want easy way, you can use PCA software < PCA beam & PCA column >
My suggestion you should make your own excel sheet.
Calculate "Moment Cap." provided by actual section of beam / column with its reinforcing is not difficult, you just need to read the book I mention above & you can make your own excel sheet.
Software sometime contain "bug", if you mastering the knowledge you can check your design - calculation & know whether the software containing "bug" or not.
I understand in practice ( in consultant firm ) using software is common matter, but, I suggest you should check at critical condition of your structure manually to ensure it.
Thx
[-] The following 4 users say Thank You to budis for this post:
  • concreteok, Dell_Brett, jaks, zuhalz
There are good excel "RC spreadsheets: V3" here on civilea that can help you
[-] The following 1 user says Thank You to seb3k for this post:
  • jaks
you can try GaLa Reinforcement which is free and supports all the widely used concrete codes
[-] The following 4 users say Thank You to rigid_joint for this post:
  • Dell_Brett, blr_over, ruaumoko, malc
Beam/column chigozie 22 10,206 07-16-2010, 11:51 AM
Last Post: chigozie
