Internal EXCEL passwords remover
Current time: 06-22-2018, 06:28 AM
Author: shpatone
Last Post: bigone
Replies 9
Views 9454
The following .xls file can be used to remove internal protections in excel (i.e. workbook & worksheet).
Instructions after downloading the file from the given link:
1. Load the file: "allinternalpasswords.xls" in excel
2. If asked, Enable Macros
3. Go to: File > Open...
4. Select and open the excel file you want to remove the protection from
5. Go to: Add-Ins > Remove Passwords or if older version execute/run macro with name "allinternalpasswords.xls!AllInternalPasswords"
6. After macro finishes task (it takes some seconds depending also on PC speed), save the unprotected workbook with a new name.
7. Your coffee is getting cold, have a sip now.
Direct Link:
.xls   allinternalpasswords.xls (Size: 28.5 KB / Downloads: 426)
WARNING: SOME EXCEL WORKBOOK AUTHORS INCLUDE ALGORITHMS THAT CHECK IF THE WORKBOOK HAS BEEN ALTERED OR UNPROTECTED. IN SOME CASES THE UNPROTECTED WORKBOOKS CAN GIVE FALSE RESULTS AND/OR LOSE FUNCTIONALITY. ALWAYS DOUBLE CHECK!!!
Also, if you modify an excel workbook by unprotecting it and you post it here, also post the original one and make a note about this in your post. Engineering is an exact science; mistakes can cost lives, money ans careers so we should be careful when modifying original code.
If you can't feed a hundred people, then feed just one.
There is a more simply way, use openoffice excell, it crashes almost all of the microsoft excell passwords.
[-] The following 4 users say Thank You to cadtfoi for this post:
  • chigozie, nhim4mat2006, jcbv, bigone
Dear Cadtfoi,
I doubt your way is more simple. The Openoffice pack is 148 MB to download and it takes also time to download, install as well as unnecessary hard drive space if you just need it for once to remove a worksheet protection. Also it is not 100% compatible with Micr0s0ft Excel, the same for Google docs etc.
The .xls file I posted is just 28 Kb, it needs no installation and it is made for MS Excel.
Cheers
[-] The following 10 users say Thank You to shpatone for this post:
  • chigozie, gelbert, ska51, Yasir, mrgoodboydatdat, ssi3k, sodapas, ravisbassi, oanm2000, smrutigandh.42
(12-23-2010, 11:22 AM)shpatone Wrote: WARNING: SOME EXCEL WORKBOOK AUTHORS INCLUDE ALGORITHMS THAT CHECK IF THE WORKBOOK HAS BEEN ALTERED OR UNPROTECTED. IN SOME CASES THE UNPROTECTED WORKBOOKS CAN GIVE FALSE RESULTS AND/OR LOSE FUNCTIONALITY.
shpatone - can you please provide some insight and/or details of these algorithms. I am curious and asking for educative purpose.
The Function code for checking if a worksheet or workbook is protected is (scroll inside window) :
PHP Code:
Function IsProtected(objXL As Object) As Boolean
Dim wksht
As Excel.Worksheet
Dim cell
As Excel.Range
Select
Case TypeName(objXL)
  Case
"Worksheet"
If objXL.ProtectContents Then
' still doesn't mean you can't edit the worksheet!
     Select Case Cells.Locked
        Case True '
all cells are locked AND worksheet is protected
IsProtected True
Exit Function
End Select
    End
If
  Case
"Workbook"
If objXL.ProtectStructure Then
      IsProtected
True
Exit Function
End If
    For
Each wksht In objXL.Worksheets
If wksht.ProtectContents Then
          Case True '
IsProtected True
Exit Function
End Select
      End
If
Next wksht
Case "Range"
If objXL.Cells.Count 1 Then
If (objXL.Locked And objXL.Parent.ProtectContents) Or (IsProtected(objXL.Parent.Parent)) Then
        IsProtected
True
Exit Function
End If
    Else
      For
Each cell In objXL
If (cell.Locked And cell.Parent.ProtectContents) Or (IsProtected(cell.Parent.Parent)) Then
          IsProtected
True
Exit Function
End If
Next cell
    End
If
End Select
End
Function
The usage is (scroll inside window) :
PHP Code:
Dim wkb As Excel.Workbook
Set wkb
ActiveWorkbook
If IsProtected(wkbThen
  Msgbox
"It's protected!"
End If
' or
Dim wksht As Excel.Worksheet
Set wksht = ActiveSheet
If IsProtected(wksht) Then
  Msgbox "It'
protected!"
End If
' or
Dim rng as Excel.Range
Set rng = Range("
A3")
If IsProtected(rng) Then
  Msgbox "
It's protected!"
End If
For more explanations go to:
[-] The following 5 users say Thank You to shpatone for this post:
  • ravisbassi, jcbv, mz55, bigone, sasan7351
I don't think that such 'protection check' can really work, as you can always see and change the program code to bypass it.
If you want to protect your code, just make a XLA file using Office 95 (not 97 or newer).
It seems to me that it's not a professional attitude to use MS-Office for commercial application development, but you can see enough examples for people trying to make money this way.
[-] The following 1 user says Thank You to ynopum for this post:
  • ravisbassi
I agree with you ynopum, the protection can be bypassed, but don't forget that the average user does not know how to do that. Also the code can be encrypted, so then it gets more difficult to "see" anything.
[-] The following 2 users say Thank You to shpatone for this post:
  • ravisbassi, engr1900
hey guys i've tried this excel sheet, it works on simple excel sheet but it does not work on LOCKED.XLS file and STK3lock.xla files. Can anyone have a file or a software to remove a protected sheet on LOCKED.XLS file and a STK3locked.xla file? Please!
regards
Jeff
[-] The following 1 user says Thank You to Jeffrey Toledo for this post:
  • engr1900
Try Excel Utilities, its a free Excel Add-ins. This have a command Break Password that worked fine for me.
[-] The following 5 users say Thank You to HomerMTY for this post:
  • chenamoy, Umer.Aleem, sasan7351, engr1900, oreslaw
(12-23-2010, 11:25 AM)cadtfoi Wrote: There is a more simply way, use openoffice excell, it crashes almost all of the microsoft excell passwords.
that is right, and i tried and working fine.
openoffice source download:
here a picture for sample file & steps:
[Image: 17935923285006700506.png]
[-] The following 8 users say Thank You to bigone for this post:
  • engr1900, Dell_Brett, oanm2000, duazo2009, hm20284, sasan7351, zonoiko, r3be1
