Civil Engineering Association eBooks Structural Books Finite Element Methods Finite Element Analysis: Theory and Application with ANSYS
 Flexi
User ID: 300
Threads: 158
Likes: 5,440 in 422 posts
Given Likes: 110
Points:23,161 EP
07-12-2009, 01:46 PM (This post was last modified: 12-08-2011, 09:53 AM by Grunf.)
Author: Saeed Moaveni | Size: 29.06 MB | Format: PDF | Publisher: Edition: 1 | Year: March 29, 1999 | ISBN: 0137850980, 9780137850983
[Image: 93692547500140057105.jpg]
While many good textbooks cover the theory of finite element modeling, this is the only text available that incorporates ANSYS as an integral part of its content. This book presents the theory of finite element method, explores its application as a design/modelling tool, and explains in detail how to use the ANSYS intelligently and effectively. It shows how to use ANSYS step-by-step to model a physical problem. Each chapter first discusses the relevant basic theory and then demonstrates it using simple problems with hand-calculations. Examples that are solved using ANSYS follow. Various sources of error that can contribute to wrong results are discussed. The design optimization and parametric programming is also included. This book is directed to students and practitioners using ANSYS.
Unique in approach and content, this book presents the theory of finite element analysis, explores its application as a design/modeling tool, and explains in detail how to use ANSYS intelligently and effectively.FEATURES * Provides comprehensive -- but not overwhelming -- coverage of finite element theory. * Helps readers learn how to use ANSYS quickly and effectively. * Shows how to use ANSYS step by step to model a physical problem. * Integrates ANSYS throughout. Each chapter: * First discusses the relevant basic theory and then demonstrates it using simple problems with hand-calculations. * Follows with examples that are solved using ANSYS. * Presents all exercises in the same manner. Some exercises require manual calculations, while others, more complex in nature, require the use of ANSYS. * Discusses various sources of error that can contribute to wrong results. * Emphasizes how to manually verify Finite Element Analysis (FEA) findings. * Devotes a section of approaches for verifying ANSYS results at the end of selected chapters. * Features a number of open-ended design problems at the end of Chapters. 7, 8, and 10. * Devotes the concluding chapter to design optimization and parametric programming with ANSYS. * Offers a brief review of fundamental principles in solid mechanics, heat transfer, and fluid mechanics. * Appendices give mechanical and thermophysical properties of some common materials used in engineering. * Provides a list of objectives and a summary for each chapter.
[-] The following 38 users Like Flexi's post:38 users Like Flexi's post
  • kowheng, kowheng, oanm2000, oanm2000, simanta, simanta, abudabeeja, abudabeeja, cgedmundo, cgedmundo, zrilek, zrilek, mishanya, mishanya, ska51, hans01, jcbv, youceftli, levanduy, sodapas, user108, fer962933, adshrt, bigone, Grunf, hcardenas, vardan, Dell_Brett, pubudu1199, slowet, Sumatra, blaze, kg85arun, Nilupa, igor1234, hm20284, Quantumm, triance
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
Points:34,110 EP
12-08-2011, 08:45 AM
Other Links (DjVU):
[-] The following 7 users Like junaid's post:7 users Like junaid's post
  • Dell_Brett, tluc, draluka, Sumatra, blaze, zrilek, Nilupa
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,704 in 1,304 posts
Given Likes: 4610
Points:80,767 EP
12-28-2011, 11:42 AM
Finite Element Analysis Theory and Application with ANSYS (3rd Edition)
Author: Saeed Moaveni | Size: 181 MB | Format: PDF | Publisher: Prentice Hall | Year: April 6, 2007 | pages: 880 |
ISBN: 0131890808 | ISBN-13: 978-0131890800
[Image: 63776483756129828952.jpg]
While many authors cover the theory of finite element modeling, this is the only book available that incorporates ANSYS as an integral part of its content. Moaveni presents the theory of finite element analysis, explores its application as a design/modeling tool, and explains in detail how to use ANSYS intelligently and effectively. Now uses Excel in solving simple finite element problems. Adds a significant number of new problems. Incorporates the latest version of ANSYS throughout. A useful reference for mechanical, civil and environmental engineers.
[Image: comments.png]
Scanned book / Chapter bookmarks / OCR / Searchable text / 161.5 MB rar / 181 MB on HDD
This is third edition of the book, which is easily checked on the inside.
When you open this e-book, on the front cover it is written "Fifth Edition". This is wrong because there is no 4th or 5th edition of this book yet.
Web resource:
[-] The following 17 users Like lisine's post:17 users Like lisine's post
  • kowheng, Dell_Brett, Sumatra, blaze, miquan, user108, hcardenas, jcbv, yakwetu, malc, tluc, subin91, zrilek, highcivil, Nilupa, ykhackhack, Quantumm
 ynopum
Burundi
User ID: 2733
Threads: 26
Likes: 2,399 in 365 posts
Given Likes: 155
Points:18,912 EP
01-08-2012, 12:18 PM (This post was last modified: 01-08-2012, 12:49 PM by 3fan.)
Author: Saeed Moaveni | Size: 56.1 MB | Format: PDF scanned grayscale, OCR searchable | Year: 2008 | pages: 880 |
The source was the big 180 MB file posted above.
I removed the watermark, and after some color corrections, reduced size more than 3 times - down to 56.1 MB
Now it is easier to download and open the document.
Dear ynopum nice work on our forum; next time please consider when you post a new thread/post it is recomanded to post each download link in separate links, thus it is easier to download for all users; maybe some links don't work in their country
This comment will be deleted soon
Post edited by moderator (3fan)
[-] The following 10 users Like ynopum's post:10 users Like ynopum's post
  • 3fan, Dell_Brett, lisine, Clouseau, isurya, sodapas, zrilek, ska51, Nilupa, ykhackhack
 junaid
User ID: 402
Threads: 209
Given Likes: 983
Points:34,110 EP
02-14-2012, 04:33 PM
Other Link (3rd Ed.):
[-] The following 4 users Like junaid's post:4 users Like junaid's post
  • Dell_Brett, zrilek, Nilupa, ykhackhack
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
Points:43,841 EP
02-14-2012, 09:14 PM
mirror for post#3
[-] The following 7 users Like ssobhan's post:7 users Like ssobhan's post
  • 3fan, Dell_Brett, subin91, mgdario, zrilek, ska51, Nilupa
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,033 in 2,186 posts
Given Likes: 42452
Points:111,158 EP
10-15-2012, 06:35 AM
Finite Element Analysis Theory and Application with ANSYS, 3rd Edition
2007 | ISBN-10: 0131890808 | 880 pages | PDF | 180 MB
[-] The following 7 users Like Dell_Brett's post:7 users Like Dell_Brett's post
  • jcbv, Nilupa, tolesa54, ska51, shadabg, ykhackhack, Civilized
 ssobhan
User ID: 1054
Threads: 335
Given Likes: 2465
Points:43,841 EP
12-15-2012, 08:25 PM (This post was last modified: 12-15-2012, 08:29 PM by ssobhan.)
Solution of Selected Problems for 1st ed.
[-] The following 5 users Like ssobhan's post:5 users Like ssobhan's post
  • ska51, jcbv, Dell_Brett, Nilupa, zrilek
Points:66,329 EP
12-18-2012, 06:47 AM
Direct Link for 1st Edition :Wink
PDF : 29.1 Mb
PDF : 29.1 Mb
3rd Edition :
PDF : 180.9 Mb
[-] The following 5 users Like shadabg's post:5 users Like shadabg's post
  • Ivan_1980, ykhackhack, Quantumm, Dell_Brett, Nilupa
 lisine
Vanuatu
User ID: 17927
Threads: 272
Given Likes: 4610
Points:80,767 EP
12-19-2012, 08:00 AM (This post was last modified: 12-19-2012, 08:02 AM by lisine.)
Third Edition - Mirror of post #4 - 56.19MB
[-] The following 11 users Like lisine's post:11 users Like lisine's post
  • kowheng, andersen3, highcivil, ykhackhack, hm20284, triance, Dell_Brett, espresso, shadabg, Nilupa, carolinandra
Pages (2): 1 2 Next »
  Finite element based fatigue calculations - Bishop and Sherratt dinu69in 3 5,031 03-18-2024, 01:17 PM
Last Post: babakfeyzi
  Concepts and Applications of Finite Element Analysis Flexi 6 6,567 04-25-2023, 08:59 AM
  MATLAB Codes for Finite Element Analysis jgarciafic 7 7,366 02-19-2022, 02:23 PM
  Solving Complex Problems for Structures and Bridges using ABAQUS Finite Element Packa carolinandra 0 2,602 10-26-2021, 07:52 PM
Last Post: carolinandra
  Finite Element Simulations with ANSYS Workbench 14 by Huei-Huang Lee - mowafi3m 3 5,488 01-20-2020, 09:53 AM
  Finite Element Simulations with ANSYS Workbench 12 by Huei-Huang Lee jamildear4u 4 5,913 01-20-2020, 09:35 AM
  Finite Element Analysis jgarciafic 1 3,632 05-10-2019, 04:40 AM
