Simpo PDF Converter Ultimate 1.1.2.0+patch
Simpo PDF Converter Ultimate 1.1.2.0| 4.37 MB
[Image: 13219793308076937211.jpg]
Simpo PDF Converter Ultimate is a 6-in-1 PDF converter to convert PDF to Word, Excle, PowerPoint, HTML, Images and Text on 32bit/64bit Windows 7/Vista/XP system. It supports batch conversion and you can easily convert PDF to Office in the fastest speed to save your time. With this allsided PDF converter, your PDF files can be converted to other formats with high output quality, images, graphic and tables will be preserved precisely.
The best PDF converter to solve all problems to convert PDF to Office, HTML, Text and Images.
• Convert PDF to Word, Excel, PowerPoint, Text, HTML and Images
• Preserve all formats like text, tables, graphic objects, hyperlinks and formatting from PDF
• Convert PDF in faster speed
• Batch convert up to 200 PDF files at a time
Features
• Easy-to-use Interface.
The interface of Simpo PDF Converter Ultimate is simple and easy to use. You can just import a batch of PDF files with drag and drop function, then click "Convert" to get wanted output file format - Word, Excel, PowerPoint, HTML, Text and Images.
• Accurately Convert PDF to Word
Simpo PDF Converter Ultimate can convert PDF to Word accurately. It preserves all formats including origianl layouts and formatting of text, tables and hyperlinks, even graphic objects like Curve, Shape and Rectangle are also retained precisely from PDF to Word.
• Easy Convert PDF to Excel
PDF Converter Ultimate provides 2 methods to convert PDF to Excel - Reserve PDF tables and Reserve whole PDF. Reserve PDF tables means that you can extract origianl text and numbers in PDF tables from PDF to Excel spreadsheet. Reserve whole PDF allows you to preserve whole PDF to Excel, text, numbers, tables and formatting. In addition, PDF Converter Ultimate supports to save PDF to Excel as .xls, .xlsx and .csv format.
• Convert PDF to PowerPoint
Demonstrating a PDF file is not easy, but you can convert PDF to PowerPoint, which allows you to present slide show to your audience conveniently. PDF Converter Ultimate converts your PDF file to PowerPoint slide by page, every PDF page is converted to one PowerPoint slide.
• Convert PDF to HTML Retaining Bookmarks
PDF Converter Ultimate can preserve hyperlinks and bookmarks from PDF to HTML. With the bookmarks in HTML, you can view the ebooks of your own will any time.
• Convert PDF to Image
With PDF Converter Ultimate, it is much easier to extract images from PDF. It also allows you to save extracted images from original PDF file with 5 types - PDF to JPEG, PDF to TIFF, PDF to BMP, PDF to PNG and PDF to GIF. These are the top 5 used images types which can fulfill your need.
• Convert PDF to Text
PDF Converter Ultimate can also works as a PDF to Text converter, you can convert PDF to plain text as well. Just choose Text as output file format, all text will be extracted in seconds wit text origianl formating saved precisely.
• Best and Time-saving PDF Converter
Simpo PDF Converter Ultimate is the best of many PDF converters. 1) Its output quality is top-grade and conversion speed is the fastest; 2) Convert PDF in two ways - Partial and Batch. Partial means that you can select any specific pages from a multi-page PDF file to convert; Batch is a time-saving way, as you can convert batch of PDF files at a time; 3) Support encrypted PDF files. Directly convert PDF files with printing and copying restrictions and convert open password protected PDF files with entering password first; 4) Support multiple output file formats - Microsoft Office Word 2003/2007/2010(.doc, .docx), Excel 2003/2007/2010(.xls, .xlsx, .csv), PowerPoint 2003/2007/2010(.ppt, .pptx), HTML format(.html), Text format(.txt) and Images format(.jpg, .tiff, .bmp, .png, .giff)
enjoy
[-] The following 16 users say Thank You to mowafi3m for this post:
  • ssi3k, blaze, gatob, ilgar, bhawk0, Hengki, kowheng, rohitksoni, oanm2000, ra_imtiaz, zainseiya, Dell_Brett, abouferass88, hignacio43, bigone, ting tsai huang
other links:
portable:
regards
Flexi
[-] The following 10 users say Thank You to Flexi for this post:
  • kowheng, zainseiya, Dell_Brett, gatob, blaze, Grunf, ska51, floatfree, ranger, abouferass88
Mirror with med.
[-] The following 11 users say Thank You to mowafi3m for this post:
  • ting tsai huang, tluc, 3fan, hcardenas, malc, floatfree, tremonti, fbx_rdnk, isurya, bigone, hignacio43
(02-09-2012, 01:01 PM)mowafi3m Wrote: Mirror with med.
mcafee prevented patch.exe and quarntined it reporting it as Generic.dx!vee (Trojan)
Disable your antivirus protection and might works good.
3fan
Xilisoft Video Converter Ultimate 5.1.3 build-0926 verongskey 1 2,072 04-21-2011, 01:45 PM
Last Post: verongskey
STDU Converter 2.0.61.0 [DJVU to PDF Converter] Dell_Brett 0 1,761 12-20-2010, 08:45 AM
Last Post: Dell_Brett
