ACI SP-265-15 Structural Concrete Beam Shear - Still a Riddle ?
Current time: 10-22-2018, 01:38 PM
Author: pssst
Last Post: pssst
Replies 0
Views 1833
Synopsis: The paper reviews the application of classical plasticity theory to shear
failure of structural concrete beams. The resistance of concrete to shearing deforma-
tions is described by the modified Coulomb failure criterion. For beams with shear
reinforcement, this leads to an upper bound solution based on yield lines minimizing
the combined work of yielding stirrups and cracking concrete, the coinciding lower
bound solution corresponding to an inclined compression field (the web-crushing
criterion). For beams without shear reinforcement, the optimal failure mechanism is
a single yield line (straight or hyperbolic) from load to support, the coinciding lower
bound solution corresponding to a compressive strut between the load and support
platens. The predicted failure mechanisms and ultimate loads are compared with
experimental evidence, and it is concluded that the plasticity approach goes a long
way toward solving the riddle of shear failure.
[Image: 90144266293721336378_thumb.png][Image: 56172927029985010691_thumb.png]
[-] The following 11 users say Thank You to pssst for this post:
  • kowheng, ravisbassi, Dell_Brett, toa011, ziggywas1, Eaky, sodapas, Umer.Aleem, jf28, Jackass, malc
A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 1,032 06-01-2014, 04:35 PM
Shear Coefficients for Timoshenko Beam Theory mariusz 3 4,054 03-01-2013, 07:05 AM
Punching Shear Retrofit Method Using Shear Bolts for Reinforced Concrete Slabs under yanburak 0 1,575 09-15-2010, 02:23 AM
Last Post: yanburak
