SCI P291: Structural Design of Stainless Steel
Current time: 10-19-2018, 01:03 AM
Author: ir_71
Last Post: concreteok
Replies 2
Views 3317
[Image: 28553775972170534329.jpg]
This document is a guide to the design of stainless steel structures for engineers. The guide gives design recommendations, design examples, section properties and member capacities for commonly used stainless steel sections. This guide applies to the design of the grades of stainless steel that are widely used in structural applications, including the austenitic grades 1.4301 (304), 1.4401 (316) and their low carbon variants. Duplex grades 1.4362 (SAF 2304) and 1.4462 (2205) are also covered. The recommendations on structural design given in the guide have, as far as is practicable, been harmonized with BS 5950-1: 2000. The guide gives recommendations on how to select the most appropriate grade of stainless steel for a given application. It provides information on the mechanical properties, physical properties and design strength of stainless steel. The guide covers aspects of material behaviour, cross-section design, member design, connections, fabrication and fire resistant design. Design examples are included to illustrate the use of the design recommendations.
Based on these design recommendations, a comprehensive set of design tables is presented, giving gross and effective section properties, section classification and member capacities for a wide range of cold formed stainless steel sections. The structural forms covered by the design tables are circular, rectangular and square hollow sections, channels, double channels back to back, equal angles and equal angles back to back. The grades of stainless steel covered in the tables are austenitic stainless steel grades 1.4301 (304), 1.4401 (316), 1.4404 (316L) and the duplex grades 1.4362 (SAF 2304) and 1.4462 (2205).
[-] The following 18 users say Thank You to ir_71 for this post:
  • Adam Smith, chenamoy, axee1980, kowheng, Dell_Brett, zrilek, lanz, Grunf, ambrish, cordoba123, toa011, oanm2000, DamaD, triance, peixoto, Nilupa, ziadjordan, bigone
Bookmarked PDF 3.83 MB | RAR 2.48 MB
[-] The following 12 users say Thank You to kowheng for this post:
  • Dell_Brett, zrilek, Grunf, shaqee, cordoba123, oanm2000, triance, cristi, Nilupa, lednar_ved, fer962933, bigone
concrete solution advocate
[-] The following 15 users say Thank You to concreteok for this post:
  • Andrew seah, bridgeengineer, ting tsai huang, er.shyams, f_slikken, PinkPant, slowet, milova, Jackass, gulilero, monter, Dell_Brett, draluka, sodapas, Aviator
