SCI Design of Composite Slabs and Beams with Steel Decking
Current time: 07-18-2018, 03:20 PM
Author: ir_71
Last Post: pezhmankhan
Replies 5
Views 4816
[Image: 91636154183178565746.jpg]
Publisher
Steel Construction Institute
Ascot, UK
Abstract
Presents a method of design consistent with BS 5950: Part 1 and Part 3.1 for simply supported composite beams as used in buildings. A total of 71 design tables for both uniform and point load cases are included to aid selection of steel beam sizes depending on span and loading, depth of the concrete slab and shape of the deck profile used. A worked example illustrates the design of a typical composite beam.
Moderator Note:
See post:
For similar/complementary material
Dell Brett
[-] The following 33 users say Thank You to ir_71 for this post:
  • Grunf, maad59, vvvv, vardan, shanta, zrilek, ravisbassi, Quantumm, jcbv, nuttapolk, toa011, sasan7351, oanm2000, ladjin, Dell_Brett, cristi, narendra, simanta, rezart, kowheng, cowboy, lednar_ved, Adam Smith, robertsas, yutt, deadlord, Nilupa, ziadjordan, gulilero, slowet, blaze, ikoleci, ykhackhack
Additional info:
Published: July 1989 by The Steel Construction Institute
Number of pages: 128
Open Library: OL8649745M
ISBN-10: 1870004396
ISBN-13: 9781870004398
[-] The following 6 users say Thank You to Grunf for this post:
  • rezart, kowheng, usman, Adam Smith, oanm2000, ykhackhack
[-] The following 24 users say Thank You to Dell_Brett for this post:
  • rezart, usman, lednar_ved, kg85arun, malc, mrco1124, robertsas, jferrer, kowheng, zainseiya, oanm2000, Grunf, Pinkto, ssi3k, lucky_b2me, cristi, STRAIN, Nilupa, simanta, user108, ajmf77, Jackass, lisine, ykhackhack
Mirror link
[-] The following 12 users say Thank You to stash for this post:
  • NBZ1400, ikoleci, lisine, knrsa, zrilek, Jackass, Dell_Brett, ykhackhack, seriousboy, Hengki, chenamoy, draluka
posted here:
with password
[-] The following 6 users say Thank You to r3be1 for this post:
  • Jackass, jcbv, ting tsai huang, subin91, Dell_Brett, lednar_ved
[-] The following 2 users say Thank You to pezhmankhan for this post:
  • Dell_Brett, Andrew seah
SCI P287: Design of Composite Beams using Precast Concrete Slabs ir_71 2 2,984 04-25-2018, 11:26 PM
Last Post: gulilero
Structural Analysis and Design of Tall Buildings: Steel and Composite Construction mybest 8 7,418 03-28-2017, 08:06 AM
Last Post: Wijono
Tall building design: steel, concrete, and composite systems asim99 2 2,333 03-28-2017, 06:16 AM
Last Post: Wijono
Optimal Design of Flexural Systems: Beams, Grillages, Slabs, Plates and Shells apocalipse 1 1,643 01-11-2015, 11:12 PM
Last Post: Veggeta
Composite Structures of Steel and Concrete: Beams, Slabs, Columns, Frames Flexi 17 13,432 10-21-2014, 08:08 PM
Last Post: r3be1
