AutoDesk Quantity Takeoff 2011
Current time: 10-19-2018, 01:15 AM
Author: BennyP
Replies 1
Views 2973
Autodesk® Quantity Takeoff building cost estimating software helps make material costing faster, easier, and more accurate. Cost estimators can create synchronized, comprehensive project views that combine important information from building information modeling (BIM) tools such as Revit® Architecture, Revit® Structure, and Revit® MEP software together with geometry, images, and data from other tools. Automatically or manually measure areas and count building components, export to Microsoft® Excel®, and publish to DWF™ format.
Downloaded from hotfile, burned and installed. In install.txt included they forgot to specify the code. Use 242C1. You can install using 000-00000000 as serial and 00000 as code. The keygenerator don't works. I checked in two computers (WinXP SP3). At this stage you can try for 30 days.
[Image: 95457506724824384053.jpg]
[-] The following 12 users say Thank You to BennyP for this post:
  • zrilek, ilgar, rezart, sasan7351, snakes, engr1900, meurus, mowafi3m, duazo2009, ChPedja, faxel, topgun45
This is a 32bit application. The keygenerator works for me only in a 64bit system.
[Image: 77716727532904593569.gif]
[Image: 19005393006729364913.gif]
[-] The following 10 users say Thank You to BennyP for this post:
  • rezart, snakes, engr1900, we_mbm, Dell_Brett, meurus, mowafi3m, cordoba123, arunsmt, ali akbar
Autodesk Quantity Takeoff 2013 BennyP 4 3,300 09-16-2012, 03:31 PM
Last Post: Mohammad6299
Autodesk Quantity Takeoff 2012 BennyP 3 4,230 04-21-2011, 04:43 AM
Last Post: niki102
Autodesk 2011 products links BennyP 0 1,533 04-02-2011, 08:45 AM
Autodesk AutoCAD LT 2011 Sp1.1 BennyP 0 1,376 10-09-2010, 05:11 PM
Autodesk AutoCAD 2011 Sp1.1 BennyP 0 1,705 10-09-2010, 05:08 PM
