Analysis: Bolt Group and Bolt Stress Analysis
[Image: 81477223942524046851.jpg]
ECCENTRIC LOADS ON BOLT GROUPS - FOR ONE VERTICAL ROW
ECCENTRIC LOADS ON BOLT GROUPS - FOR TWO VERTICAL ROWS
ECCENTRIC LOADS ON BOLT GROUPS - FOR THREE VERTICAL ROWS
ECCENTRIC LOADS ON BOLT GROUPS - FOR FOUR VERTICAL ROWS
Based on the Instantaneous Center of Rotation Method and Alternate Method 2 Using Table XI from AISC 9th Ed. Manual (ASD)
BOLT GROUP ANALYSIS Using the Elastic Method for up to 25 Total Bolts
BOLT GROUP ANALYSIS Using the Elastic Method for up to 75 Total Bolts
BOLT STRESS ANALYSIS
For High-Strength Bolts Subject to Tension and/or Shear Per AISC 9th Edition Manual (ASD)
735KB XLS
[-] The following 19 users say Thank You to usman for this post:
  • kowheng, Dell_Brett, bhawk0, ilgar, jcbv, pedzaquino, kg85arun, ngcanhtoan, triance, oanm2000, robertsas, goober, we_mbm, tremonti, hcardenas, virusz158, Grunf, kaci, blaze
@odiclas
Use forum standard password for zip file
[-] The following 5 users say Thank You to ykhackhack for this post:
  • Diquan, ting tsai huang, k2kyaw, odiclas, blaze
Mirror lnk:
[-] The following 5 users say Thank You to ingchio for this post:
  • malc, nickycruz, Andrew seah, ykhackhack, eliseo.as
Anchor Bolt Design usman 1 4,252 02-03-2019, 03:35 AM
Pile Group Analysis for Rigid Pile Cap usman 1 4,566 05-18-2017, 10:49 PM
CivilBay Anchor Bolt Design With Anchor Reinforcement ACI 318-08 (TRIAL) michenerpark 9 11,383 07-24-2015, 10:40 AM
Last Post: Dell_Brett
TEK 12-03C - MSJC 2013 - Masonry Anchor Bolt Design malc 0 4,526 07-03-2014, 10:59 AM
Last Post: malc
Weld Group Analysis usman 1 3,553 09-18-2012, 04:59 AM
Last Post: usman
