Journal of Earthquake Engineering
Current time: 09-19-2018, 01:28 PM
Author: Sumatra
Last Post: Sumatra
Replies 34
Views 20870
Hi guys,
I dedicate this thread to share the articles published in
JOURNAL OF EARTHQUAKE ENGINEERING.
[Image: 75919411909586170889.jpg]
I start with the first edition of the journal that published in 1997 (vol 1 issue 1). I welcome you to share your collection fro this journal per issue based (not per article please).
Content of vol.1 issue 1:
Surface-Wave Magnitude Calibration for European Region Earthquakes
--N. N. Ambraseys and M. W. Free
Characteristics of Lateral Spreading in Liquefied Deposits During the 1995 Hanshin-Awaji Earthquake
--Kenji Ishihara, Koji Yoshida and Mitsuru Kato
A Review of Seismic Safety Considerations in the Life Cycle of Critical Facilities
--Aybars Gürpinar
Inferences for Design, Insurance and Planning from Damage Evaluation in Past New Zealand Earthquakes
--D. J. Dowrick and D. A. Rhoades
Nonlinear Response of Soils to Horizontal and Vertical Bedrock Earthquake Motion
--Bagher Mohammadioun
Procedure and Spectra for Analysis of RC Structures Subjected to Strong Vertical Earthquake Loads
--A. S. Elnashai and A. J. Papazoglou
Displacement-Based Seismic Assessment of Reinforced Concrete Buildings
--M. J. N. Priestley
Conceptual Design of Isolation Systems for Bridge Structures
--Gian Michele Calvi and Alberto Pavese
Seismic Design and Response of Bare and Masonry-Infilled Reinforced Concrete Buildings Part I: Bare Structures
--M. N. Fardis and T. B. Panagiotakos
Response of Unreinforced Masonry Buildings
--Daniel P. Abrams
Let's share..
[-] The following 19 users say Thank You to Sumatra for this post:
  • robertsas, civilphongvan, kowheng, miquan, subin91, hazus, isurya, Dell_Brett, iceman84, oanm2000, rcnet, fer962933, malc, blaze, Adam Smith, zrilek, labofrock, cve_jule, pssst
Vol. 1 Issue 2 (1997)
PEAK STRONG MOTION ATTENUATION RELATIONS FOR HORIZONTAL AND VERTICAL GROUND DISPLACEMENTS
N. J. Gregor; B. A. Bolt
THE KRASNOVODSK (TURKMENISTAN) EARTHQUAKE OF 8 JULY 1895
N. N. Ambraseys
A NON-PARAMETRIC APPROACH TO ATTENUATION RELATIONS
Peter Fajfar; Iztok Perus
INFLUENCE OF CAPACITY DESIGN METHOD ON THE SEISMIC RESPONSE OF R/C COLUMNS
A. J. Kappos
DUCTILITY AND LOAD CARRYING CAPACITY PREDICTION OF STEEL BEAM-TO-COLUMN CONNECTIONS UNDER CYCLIC REVERSAL LOADING
Claudio Bernuzzi; Luis Calado; Carlo A. Castiglioni
Let's share...
[-] The following 15 users say Thank You to Sumatra for this post:
  • kowheng, hazus, Dell_Brett, iceman84, oanm2000, rcnet, iashas24, fer962933, malc, faxel, blaze, Gkatzogias, zrilek, Grunf, pssst
Hi guys,
If you think you can acces the following journal's link:
then you can also contribute in sharing the article at this thread, especially the recent issues of this journal. Let's share..
Thank you.
[-] The following 6 users say Thank You to Sumatra for this post:
  • iceman84, fer962933, faxel, zrilek, Grunf, pssst
Vol. 1 Issue 3 (1997)
SEISMICITY AND STRAIN IN THE GULF OF CORINTH (GREECE) SINCE 1694
N. N. Ambraseys; J. A. Jackson
SEISMIC DESIGN AND RESPONSE OF BARE AND MASONRY-INFILLED REINFORCED CONCRETE BUILDINGS. PART II: INFILLED STRUCTURES
M. N. Fardis; T. B. Panagiotakos
THE DAMAGE OF HIGHWAY BRIDGES IN THE 1995 HYOGO-KEN NANBU EARTHQUAKE AND ITS IMPACT ON JAPANESE SEISMIC DESIGN
Kazuhiko Kawashima; Shigeki Unjoh
EXPERIMENTAL ASSESSMENT OF THE GLOBAL CYCLIC DAMAGE OF FRAMED R/C STRUCTURES
Paolo Negro
SIMPLIFIED EVALUATION OF EARTHQUAKE-INDUCED PERMANENT DISPLACEMENTS OF SHALLOW FOUNDATIONS
R. Paolucci
ENGINEERING EVALUATION OF THE 1 OCTOBER 1995 DİNAR EARTHQUAKE (ML = 5.9)
Haluk Sucuoğlu; Alphan Nurtuğ; Oktay Ergünay; Sinan Ğencosu
[-] The following 14 users say Thank You to Sumatra for this post:
  • kowheng, Dell_Brett, iceman84, oanm2000, yantonegr, rcnet, fer962933, malc, faxel, blaze, Gkatzogias, zrilek, Grunf, pssst
Vol. 1 Issue 4 (1997)
THE SEISMICITY OF THE EASTERN MEDITERRANEAN REGION 550-1 BC: A RE-APPRAISAL
N. N. Ambraseys; D. White
RESPONSE OF STRUCTURES TO VARIOUS SEISMIC ENVIRONMENTS AND SUPPORTING MEDIA
Ferhun Cem Caner; Yalçin Mengi
REHABILITATION OF REINFORCED CONCRETE COLUMNS USING CORRUGATED STEEL JACKETING
A. Ghobarah; A. Biddah; M. Mahgoub
ENERGY-BASED TECHNIQUE FOR SEISMIC PERFORMANCE ASSESSMENT OF INTERIOR BEAM-COLUMN JOINTS
El Mostafa M. Higazy; Amr S. Elnashai
SEISMIC FRAGILITY OF LRC FRAMES WITH AND WITHOUT MASONRY INFILL WALLS
Khalid M. Mosalam; Gustavo Ayala; Richard N. White; Christopher Roth
SEISMIC TORSIONAL EFFECTS ON DUCTILE STRUCTURAL WALL SYSTEMS
T. Paulay
Vol. 2 Issue 1 (1998)
A NOTE ON THE POINT SOURCE APPROXIMATION IN GROUND MOTION ATTENUATION RELATIONS
N. N. Ambraseys; M. Srbulov
PREDICTION OF THE BEHAVIOUR OF TOP-AND-SEAT CLEATED STEEL BEAM-TO-COLUMN CONNECTIONS UNDER CYCLIC REVERSAL LOADING
Claudio Bernuzzi
ANALYTICAL MODELS FOR BRICK MASONRY INFILLED R/C FRAMES UNDER LATERAL LOADING
A. J. Kappos; K. C. Stylianidis; C. N. Michailidis
A STUDY OF SITE EFFECTS AND SEISMIC RESPONSE OF AN INSTRUMENTED BUILDING IN MEXICO CITY
R. Meli; E. Faccioli; D. Muria-Vila; R. Quaas; R. Paolucci
EFFECT OF COLUMN CAPACITY DESIGN ON EARTHQUAKE RESPONSE OF REINFORCED CONCRETE BUILDINGS
T. B. Panagiotakos; M. N. Fardis
WAVE PROPAGATION THROUGH SOILS IN CENTRIFUGE TESTING
J. -F. Semblat; M. P. Luong
[-] The following 16 users say Thank You to Sumatra for this post:
  • Dell_Brett, aslam, kowheng, iceman84, oanm2000, yantonegr, rcnet, fer962933, malc, faxel, blaze, Gkatzogias, zrilek, Grunf, pssst, Hengki
Vol. 2 Issue 2 (1998)
STABILISATION OF AN EARTH DAM USING DRIVEN PRESTRESSED CONCRETE PILES
W. D. L. Finn; R. H. Ledbetter; R. L. Fleming Jr; T. W. Forrest; S. T. Stacy
ESTIMATION OF REQUIRED SEPARATIONS BETWEEN ADJACENT STRUCTURES UNDER SPATIAL GROUND MOTIONS
Hong Hao; Xueyi Liu
EFFECTIVENESS OF RC BEAM-COLUMN CONNECTION REPAIR USING EPOXY RESIN INJECTIONS
C. G. Karayannis; C. E. Chalioris; K. K. Sideris
A SIMPLIFIED METHOD FOR ELASTIC SEISMIC ANALYSIS OF HILL BUILDINGS
S. Kumar; D. K. Paul
A UNIFORM ESTIMATION OF SOME BASIC GROUND MOTION PARAMETERS
S. K. Sarma; M. Srbulov
THE COLFIORITO EARTHQUAKE SEQUENCE OF SEPTEMBER–OCTOBER 1997: SURFACE BREAKS AND SEISMOTECTONIC IMPLICATIONS FOR THE CENTRAL APENNINES (ITALY)
R. Basil; V. Bosi; F. Galadini; P. Galli; M. Meghraoui; P. Messina; M. Moro; A. Sposato
EVIDENCE FOR SURFACE FAULTING DURING THE SEPTEMBER 26, 1997, COLFIORITO (CENTRAL ITALY) EARTHQUAKES
Giuseppe Cello; Giovanni Deiana; Paolo Mangano; Stefano Mazzoli; Emanuele Tondi; Luca Ferreli; Laura Maschio; Alessandro Maria Michetti; Leonello Serva; Eutizio Vittori
A QUICK SURVEY OF LOCAL AMPLIFICATIONS AND THEIR CORRELATION WITH DAMAGE OBSERVED DURING THE UMBRO-MARCHESAN (ITALY) EARTHQUAKE OF SEPTEMBER 26, 1997
Marco Mucciarelli; Giancarlo Monachesi†
[-] The following 13 users say Thank You to Sumatra for this post:
  • miquan, kowheng, iceman84, RANA WASEEM, oanm2000, Dell_Brett, yantonegr, rcnet, fer962933, blaze, Gkatzogias, zrilek, Grunf
JOURNAL of EARTHQUAKE ENGINEERING
Vol. 2 Issue 3 (1998)
1. SEISMIC RESPONSE OF A SECONDARY SYSTEM MOUNTED ON A TORSIONALLY COUPLED NON-LINEAR PRIMARY SYSTEM
ABHIJIT K. AGRAWAL and T. K. DATTA
2. CYCLIC RESPONSE OF BRIDGE KNEE JOINTS WITH CIRCULAR COLUMNS
JASON M. INGHAM, M. J. NIGEL PRIESTLEY and FRIEDER SEIBLE
3. DURATION AND ENERGY CHARACTERISTICS OF GREEK STRONG MOTION RECORDS
P. K. KOLIOPOULOS, B. N. MARGARIS and N. S. KLIMIS
4. DEFORMATION BUILD UP WITHIN A GRANULAR ASSEMBLAGE DURING AN INTENSE EARTHQUAKE
KAZUO KONAGAI, TAKASHI MATSUSHIMA and ATSUSHI MIKAMI
5. A FIBRE FINITE BEAM ELEMENT WITH SECTION SHEAR MODELLING FOR SEISMIC ANALYSIS OF RC STRUCTURES
GIULIO RANZO and MARCO PETRANGELI
6. ESTIMATION OF GROUND MOTION ACCELERATION AND BUILDING RESPONSE TO A LONG DISTANCE EARTHQUAKE
N. F. TAO and J. M. W. BROWNJOHN
[-] The following 11 users say Thank You to Sumatra for this post:
  • melkat, kowheng, iceman84, oanm2000, rcnet, fer962933, malc, blaze, Gkatzogias, zrilek, Grunf
Vol. 2 Issue 4 (1998)
1. A THREE-DIMENSIONAL MODEL FOR VULNERABILITY ANALYSIS OF SLENDER MEDIEVAL MASONRY TOWERS
Siro Casolo
2. PHENOMENOLOGICAL TWO-PARAMETER MODEL FOR DYNAMIC DAM-RESERVOIR INTERACTION
G. R. Darbre
3. REPAIR AND RETROFITTING OF RC WALLS USING SELECTIVE TECHNIQUES
A. S. Elnashai; R. Pinho
4. SEISMIC RELIABILITY ASSESSMENT OF EXISTING REINFORCED CONCRETE BUILDINGS
A. Ghobarah; N. M. Aly; M. El-Attar
5. USING GIS IN THE PROBABILISTIC ASSESSMENT OF EARTHQUAKE TRIGGERED LANDSLIDE HAZARDS
Joseph M. Mankelow; William Murphy
6. RELIABILITY AND APPLICABILITY OF NAKAMURA'S TECHNIQUE USING MICROTREMORS: AN EXPERIMENTAL APPROACH
Marco Mucciarelli
[-] The following 12 users say Thank You to Sumatra for this post:
  • Dell_Brett, melkat, kowheng, iceman84, jcoronellr, oanm2000, rcnet, fer962933, malc, blaze, Gkatzogias, zrilek
Vol. 3 Issue 1 (1999)
1. DISPLACEMENT SPECTRA FOR SEISMIC DESIGN
Julian J. Bommer; Amr S. Elnashai
2. BRACED FRAMES WITH HYSTERETIC DISSIPATIVE DEVICES: SEISMIC RESPONSE AND DESIGN CRITERIA
Piero Colajanni
3. SOFTENING EFFECTS ON THE SEISMIC RESPONSE OF NON-DUCTILE CONCRETE FRAMES
A. Ghobarah; T. Aziz; H. Abou-Elfath
4. INSTANTANEOUS OPTIMAL CONTROL FOR SEISMIC ANALYSIS OF NON-LINEAR STRUCTURES
K. Huang; R. Betti†; M. M. Ettouney†
5. DISPLACEMENT DESIGN SPECTRA
Stavros V. Tolis; Ezio Faccioli
  • kowheng, Dell_Brett, iceman84, oanm2000, DamirDz, fer962933, malc, blaze, Gkatzogias, zrilek, Grunf, pssst
Size: 5.3 MB | Format: PDF | Publisher: Taylor & Francis | Year: 1999
----- VOLUME 3 ISSUE 2 ------
THE EFFECTIVE DURATION OF EARTHQUAKE STRONG MOTION
Julian J. Bommer; Alejandro Martínez-Pereira
SEISMIC DESIGN OF OPEN-STOREY INFILLED RC BUILDINGS
M. N. Fardis; P. Negro; S. N. Bousias; A. Colombo
SEISMIC STRENGTHENING AND REPAIR OF BYZANTINE CHURCHES
P. Gavrilovic; V. Sendova; W. S. Ginell
SITE-DEPENDENT AMPLIFICATION FUNCTIONS AND RESPONSE SPECTRA IN GREECE
N. S. Klimis; B. N. Margaris; P. K. Koliopoulos
SHEAR MODULUS AND DAMPING OF CLAYEY SANDS
G. X. Wang; J. Kuwano
DIRECT LINKS thumbup
Size: 9.2 MB | Format: PDF | Publisher: Taylor & Francis | Year: 1999 (Vol. 3 Issue 3)
A THEORETICAL ATTENUATION MODEL FOR EARTHQUAKE-INDUCED GROUND MOTION
S. Ólafsson; R. Sigbjörnsson
THE BOVEC (SLOVENIA) EARTHQUAKE, APRIL 1998: PRELIMINARY QUANTITATIVE ASSOCIATION AMONG DAMAGE, GROUND MOTION AMPLIFICATION AND BUILDING FREQUENCIES
CONSTANT-DAMAGE DESIGN SPECTRA
Pennung Warnitchai; Phaiboon Panyakapo
THE AIGIO (GREECE) SEISMIC SEQUENCE OF JUNE 1995: SEISMOLOGICAL, STRONG MOTION DATA AND EFFECTS OF THE EARTHQUAKES ON STRUCTURES
V. A. Lekidis; C. Z. Karakostas; P. P. Dimitriu; B. N. Margaris; I. Kalogeras; N. Theodulidis
GEOTECHNICAL AND GEOPHYSICAL DESCRIPTION OF EURO-SEISTEST, USING FIELD, LABORATORY TESTS AND MODERATE STRONG MOTION RECORDINGS
K. Pitilakis; D. Raptakis; K. Lontzetidis; Th. Tika-Vassilikou; D. Jongmans
A DISPLACEMENT-BASED APPROACH FOR VULNERABILITY EVALUATION OF CLASSES OF BUILDINGS
Gian Michele Calvi
  • kowheng, iceman84, Dell_Brett, kmmh76, fer962933, malc, blaze, Gkatzogias, zrilek, Grunf, pssst
Journal Earthquake Engineering & Structural Dynamics - Papers lisine 5 3,717 02-12-2013, 11:56 AM
Journal Earthquake Engineering and Engineering Vibration - Papers lisine 0 1,054 12-28-2012, 12:49 PM
Journal Soil Dynamics and Earthquake Engineering - Papers lisine 1 1,598 12-19-2012, 10:08 AM
Journal: Earthquake Engineering & Structural Dynamics faros3000 6 4,735 11-05-2012, 01:50 PM
Last Post: mybest
Earthquake Spectra Journal : "Evaluation of Strength Reduction Factor" budis 2 2,650 12-18-2010, 01:15 PM
Last Post: Grunf
