Spectrum reponse file in SAP2000 V14
Current time: 01-18-2018, 08:23 PM
Author: SMAILIFE
Last Post: SMAILIFE
Replies 5
Views 2964
in SAP2000 V14
how i define and enter the spectrum reponse file (from file) ?
please help me
click on the icons below
01 ) DEFINE
02) FUNCTION
AFTER YOU CHOSE responces SPECTRUM
after you choose from file and then click on "add new function
Moderator Notes:
Please use "NEW REPLY" button next time. You may be warned for spamming if you kept replying with "REPLY" button (quoted text without good reason).
but in version 14 no FUNCTION icon found
help me!!!!!!!
Dear Smilife,
yes there is, mine ver.14 as well.
click DEFINE > FUNCTIONS > RESPONSE SPECTRUM > select from file in Choose Function Type to Add > Add New Function > Select Frequency vs Value or Period vs Value > Browse > select your file > View the file, if you want to make sure your file format > key in the Header Lines to Skip > Display Graph, to see your considered graph.
Hope it helps
[-] The following 1 user says Thank You to Sumatra for this post:
  • TAFATNEB
after you select RS txt files, don't forget to click "Convert to User Defined" this command make avoid dependencies. S2K files still works if you accidentally deleted RS txt files or works in others PC where you forget to includes and copy these files.
thank you all
but the problem is in my SAP2000 V14, after uninstalation , V14.1 it works 100%
:clap::clap::clap:
User specified table format file - SAP2000 v14.1.0 Coaster 0 1,167 05-03-2010, 04:48 AM
Last Post: Coaster
How to open a Sap2000 file in Prosteel? kozdil 1 1,342 01-28-2010, 11:12 AM
Last Post: mig21
SAP2000 edb file melkat 1 2,095 01-02-2010, 04:47 PM
Last Post: asim99
