HydeSoft Computing DPlot 2.2.9.8
New version and new medicine not detected as virus
DPlot graphs and manipulates 2D and 3D data from a variety of sources in many different formats. While designed for scientists, engineers, and other technical fields, DPlot's straightforward interface will appeal to anybody interested in creating presentation-quality X-Y plots and/or contour plots of 3D data. DPlot runs on Windows 95, 98, 2000, ME, NT, 2003, XP, Vista, and 2008.
DPlot include these features:
• Multiple scaling types, including linear, logarithmic, and probability scales on the X and/or Y axes.
DPlot also provides several special purpose scale types, including grain size distribution plots, tripartite grids (shock spectra), polar charts, triangle plots, N1.85 hydraulic scales, and Mercator projection.
• DPlot Jr now supports file export plugins. It is distributed with image export plugins for BMP, GIF, JPG, PNG, and TIF formats.
• The legend in XY plots may now contain line breaks (using the character sequence \n) in the same way that the title lines and axis labels do.
[Image: 79705638828036097257.jpg]
[-] The following 10 users say Thank You to BennyP for this post:
  • kowheng, hernansgz, henrybill, cace-01, ska51, theanhpe, Dell_Brett, oanm2000, alibouafia, isurya
Dear BennyP,
All links to the above DPlot seem inactive. Please do you mind checking and clarifying? I will be obliged if you cared to send active links.
[-] The following 1 user says Thank You to hmwere for this post:
  • alibouafia
This is a good example how you can rely on other links. The software producers search for ilegal software and ask the sharing hosts to delete. In this case because is a small file i uploaded in my account. Unfortunately i can't do the same for huge files (look at Autodesk releases) and this is the big problem of software section.
Look in books section and you will see dead links but every day someone add new links because in general the ebooks are small files.
RAR Password: FromCivilEA
[-] The following 6 users say Thank You to BennyP for this post:
  • ravisbassi, isurya, hmwere, Dell_Brett, faros3000, oanm2000
Update HydeSoft Computing DPlot v2.3.0.1
Activation of Reg. code: archive
OS: Windows XP, Vista, Windows 7
however, as reported by ...
... 27 of the 43 antivirus report analyzed the patch it with malicious code.
[Image: 01890770905877334263.jpg]
[-] The following 5 users say Thank You to henrybill for this post:
  • ilgar, Dell_Brett, meurus, oanm2000, isurya
HydeSoft Computing DPlot 2.2.7.5
[Image: 64615107800602459676.jpg]
[-] The following 5 users say Thank You to mowafi3m for this post:
  • Dell_Brett, milvio, usman, ssobhan, oanm2000
HydeSoft Computing DPlot 2.2.6.0 oanm2000 0 1,736 06-14-2009, 08:50 PM
Last Post: oanm2000
