Autodesk AutoCAD LT 2011 Sp1.1
As a result of detailed information from customers who used the Customer Error Reporting Utility, a number of problems were identified and fixed. Updates have been made in the following commands and features:
2D Display
3D Navigation Tools
Annotation Scaling
Attributes
Customize User Interface (CUI)
DGN Support
External References
File Navigation
General UI
Graphic System
Hatch
Inquiry
Layer
Open/Save
Other
Parametric Drawing
Partial Open
PDF Export
Ribbon
Selection
Selection Highlighting
General Updates
The following defects have been fixed:
.NET API
.NET applications built for AutoCAD 2010 may not run on AutoCAD 2011.
When opening multiple drawings, the minimize and maximize buttons may not always be visible.
You may experience a random exception when loading custom ARX applications.
2D Display
When using Software Acceleration, AutoCAD may become unstable.
3D Cache
When VSINTERSECTIONEDGES is set to “0”, Camera preview can be extremely slow.
3D Modeling
AutoCAD may become unstable when stretching along the Z-axis of the Gizmo.
Using the Gizmo grip on a 3D model may not work correctly from the right-click menu.
3D Navigation Tools
Navigation Bar tooltips may cause AutoCAD to become unstable when switching between drawings.
Clicking on the “X” to close AutoCAD may fail if the drawing is maximized, and both the ViewCube® and SteeringWheels® function are enabled.
Orbiting 3D models does not degrade when Adaptive Degradation is checked in the Performance Tuner and uses the 3D Connexion device.
AutoCAD may become unstable when using the Look tool in the WHEEL command.
AutoCAD may become unstable when using 3D Orbit in degradation mode with 3Dconnexion devices.
AutoCAD may become unstable when using the Walk tool in the SteeringWheels feature with degradation and when FPS is set to a limit of 30.
Annotation Scaling
Drawings containing 100 or more annotation scales cannot be reset.
ARX
Third-party applications may fail when using "removeCmd" in custom ARX applications.
Attributes
Multiline attributes in a dynamic block created in AutoCAD 2011 may not display in AutoCAD 2010.
Command Line
With Dynamic Mode set to “0”, you may not be able to input Japanese or Chinese characters at the command line.
Customer Involvement Program
AutoCAD fails to start due to Customer Involvement Program on Windows 7 workstations with Windows 2008 Server on the same subnet.
CUI
When an Enterprise menu is loaded, the Workspace control in the CUI Editor may be grayed out.
Unable to copy and paste toolbar controls in the CUI Editor.
When switching profiles that point to a CUIx file cannot be found, AutoCAD may become unstable.
When using "^P" in a macro, the MENUECHO is not displayed properly.
Digitizer
AutoCAD will display a CER (Customer Error Report) dialog when exiting AutoCAD with a digitizer configured.
DGN Support
DGNIMPORT command may not work with the option to ignore external references.
Dimensions
Some AutoCAD Mechanical objects cannot be selected after being inserted as a block and exploded.
AutoCAD may become unstable when using eTransmit on drawings containing multileaders.
Display Acceleration
AutoCAD may become unstable when a password-protected screen saver displays on the screen.
Display Drivers
May have issues updating the Graphics Card drivers on Windows Vista or Windows 7.
Some display drivers may show up as certified even though they were not certified.
DWG
WBLOCK may be unable to save the drawing to the AutoCAD 2000 file format for “DWG” and “DXF”.
External References
AutoCAD may become unstable when an External Reference is reloaded after XOPEN, EDIT, or SAVE.
Graphic System
AutoCAD may become unstable when opening multiple drawings in the same session when running out of video memory.
AutoCAD may become unstable when opening large amounts of drawings.
Hatch
Hatch may not display properly when dynamic blocks are part of the boundary and live preview is enabled.
Some hatch objects on a newly thawed layer may require a “REGEN” to display.
Some custom hatch patterns may not display in the Ribbon panel.
AutoCAD may become unstable when using grips to select hatches in some drawings.
AutoCAD may become unstable when editing annotative hatch through the Ribbon.
Hatch Scale may revert to 1 when setting transparency and angle on a hatch pattern on a 64-bit operating system.
Help
Welcome Screen Videos may not play on 64-bit operating systems.
Searching Online Help may be slow.
Layer
Changing layers transparently from the Ribbon will not update to the new layer when you complete the command.
Layer properties cannot be changed transparently from the Ribbon.
Licensing
Cascading license can't be checked out if one of the distributed server machines doesn't exist on the network.
AutoCAD cannot get a license from the distributed server when one of servers is stopped.
AutoCAD may become unstable when plotting a drawing with plot transparency set to "On".
Materials
Protein Materials values created on a 64-bit operating system will not work on a 32-bit operating system.
When FBXEXPORT is using the default settings, de-selecting the Insert as Block option in FBXIMPORT results in nothing being imported.
MText
Mtext Paragraph spacing cannot be removed.
Text in AutoCAD Mechanical-created Fit dimension can change unexpectedly after DDEDIT.
ObjectDBX
Unable to export multi-line attribute values with ObjectDBX.
OLE (Object Linking & Embedding)
Drawings with OLE objects saved as a DXF file no longer contain OLE options.
Open/Save
AutoCAD may become unstable when using Undo on large drawings.
Other
FBX® files imported from Autodesk 3ds Max will not import unless materials are unchecked.
AutoCAD may become unstable if a drawing REGEN occurs after editing a block.
AutoCAD will not take advantage of the 3-gigabyte switch when enabled on a 32-bit operating system.
Color book values may not display properly in AutoCAD
Partial Open
AutoCAD may become unstable when SDI (Single Document Interface) is set to 1, while editing drawings with OPENPARTIAL are set to 1.
PDF Export
Adobe Reader may display a warning message “Cannot find or create the font “ArialMT” when opening PDF files created in AutoCAD.
Publish
AutoCAD may become unstable when publishing large drawings to PDF.
Raster Design
AutoCAD may become unstable when inserting some BMP images.
Saving with ISAVE, ISAVEAS, and ISAVE again may cause an error message saying that you cannot save the file.
Ribbon
AutoCAD may become unstable in a side-by-side install if the files tab path points to the Install Directory of AutoCAD 2010.
AutoCAD may become unstable when Regional and Language Options are set to Turkish language.
Ribbon Fold panels cannot be transferred in the CUI Editor.
AutoCAD may become unstable if you have a "." in your menugroup name.
While in a command, changing the workspace from the Quick Access toolbar will not work.
Loading custom toolbars from the Ribbon may fail.
Section & Flatten
All cut-away geometry in sectionplane may not display properly when selecting “Show Cut-away Geometry”.
Selection Cycling displays when none should be visible.
AutoCAD may become unstable when holding control and hovering over intersections of lines.
Changing the Selection Cycling toggle from "Off" to "On" and then quitting AutoCAD may cause you to receive an error report.
AutoCAD may become unstable after using the "CapturePreviewImage" method
Snaps
Crosshairs do not extend across the screen when set to 100% in isometric snap style.
Visual Lisp
Visual Lisp may display an error message when using ads_defun and ads_regfunc calls in AcApp.arx.
When using the lisp function, "vl-directory-files" may cause AutoCAD to become unstable if the directory path is long.
  • Dell_Brett, psiglos, pakpu, faxel
Autodesk AutoCAD v2010 x86 & x64 Eng (DVD-ISO) [NoPE]+AutoCAD Civil 3D 2009 kamran 1 2,777 04-20-2014, 08:31 PM
Last Post: cenlara
AUTODESK AUTOCAD 2011 English WIN32 & WIN64 BennyP 2 5,249 03-25-2012, 09:52 AM
AUTODESK AUTOCAD MAP 3D 2011 WIN32 & WIN64 BennyP 1 2,086 11-29-2011, 04:55 AM
Last Post: kgb1968
AUTODESK AUTOCAD CIVIL3D 2011 WIN32 & WIN64 BennyP 3 8,809 11-09-2011, 07:05 PM
Autodesk 2011 products links BennyP 0 1,576 04-02-2011, 08:45 AM
