AUTODESK FACTORY DESIGN SUITE PREMIUM 2011 WIN32 & WIN64
WIN32: 6.84 GB | WIN64: 7.40 GB
Create Compelling 3D Visual Layouts. Autodesk® Factory Design Suite Premium 2011 software is designed for the layout user who needs to create compelling 3D visual layouts of machine lines and entire manufacturing facilities. * Create or import 2D layouts, * Drop intelligent 3D factory content on top of the 2D floor plan, * Easily try different “what-if” scenarios, * Communicate ideas and build layout proposals in 3D.
Includes:
AutoCAD® Architecture
Autodesk® Inventor®
Autodesk® Navisworks® Simulate
Autodesk® Vault®
Autodesk® Factory Design Utilities
Downloaded from the hotfile link and installed 64bit version. A lot of time for downloading, a lot of time for burning and the same for installation. Need a double layer DVD, when installing build a temporary folder of 13.7 GB and the installation folder is 7.44GB. Not checked other folders Autodesk install more. The screenshots are from the installation process, see the dots in the lower side of first one (continue to the second) and other dots in the lower side of the second, continue (enough screenshots). A real dinosaur.
[Image: 46830944216078093710.gif]
[Image: 67828434771514955957.gif]
  • cordoba123, BennyK, ilgar, snakes, oanm2000
AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 3,995 04-21-2018, 10:51 PM
Last Post: joker™
AutoDesk Infrastructure Design Suite Ultimate 2018 giovas 0 1,420 06-11-2017, 05:08 PM
Last Post: giovas
Autodesk Product Design Suite Ultimate 2018 BennyP 0 1,630 04-15-2017, 02:11 PM
Autodesk Building Design Suite Ultimate 2018 BennyP 0 1,769 04-14-2017, 03:00 PM
AutoDesk Infrastructure Design Suite Premium 2018 BennyP 0 1,351 04-14-2017, 02:34 PM
