ETABS
Current time: 09-19-2018, 09:37 AM
Author: juice
Last Post: RANA WASEEM
Replies 117
Views 84112
ETABS
To ETABS newbies, always check your "GLOBAL FORCE BALANCE RELATIVE ERRORS" in Last Analysis Run Log.
Don't get too excited at once on the output. ;)
[-] The following 12 users say Thank You to juice for this post:
  • alexcv, alexcv, Grunf, Grunf, levanduy, levanduy, Yasir, Yasir, blackjack, zrilek, deadlord, stigtg
heyy juice... please explain.. how to check it... thanks in advance
Y@sir
Hi Yasir, go to File menu after analysis is complete, click on Last Analysis Log, and check the text file for GLOBAL FORCE... The errors are in percentage.
[-] The following 2 users say Thank You to juice for this post:
  • Yasir, Yasir
hello, Juice, Yasir,
Plz correct (guide) me if i am wrong :
(1) Two way slabs shall be modelled as SHELL and need meshing
(2) One way slabs shall be modelled as MEMBRANE and NO need meshing
(3) Stiffnes modifiers for beams,columns,walls,slabs needed on when nonlinear
analysis not performed.
(4) ETABS only gives area of reinforcement for columns & beams (section to be
designed & not to be checked) and not the dia of bars and its arrangement.
(5) for beam we get steel requirement at column face, mid span only and not at
other sections of beam. How to decide upto which distance extra top steel at
support and extra stirrups at end required?
(02-02-2009, 07:37 AM)aslam Wrote: hello, Juice, Yasir,
Hi Aslam,
Answers to your queries:
1) Two way slabs - model these as membrane; preferably with meshing
2) One way slabs - yes; as membrane; preferably with meshing
3) modify your beam and column stiffness; if you're doing linear analysis
4) ETABS will give you the required area of reinforcements
5) Remember ETABS is not a black box for design; use your engineering judgement -- we're supposed to be structural engineers not encoders ;)
I hope these help.
juice
[-] The following 5 users say Thank You to juice for this post:
  • Grunf, Grunf, mig21, levanduy, narendra
Thanx Juice,
Can u suggest me most common values of stiffness modifiers for columns, beams, walls etc.
I read somewhere that two slabs shall be modeled as shell to have both Membrane(in plane forces) +Plate (bending) behavior. If u model it as memebrane there will not be any bending.
Plz clearify.
Hi Aslam,
I hope these help.
juice
Hi Aslam,
I hope these help.
juice
Hi everyone
1) Agree
2) Agree
3) not really sure about that
4) For beams ETABS will give you the required area of reinforments, but for columns also check the reinforments that you asign for the column.
5) Agree
Bye..
yucapareja
1. Best source of recommended values - the concrete design code used in your country
2. Paulay and Priestly's book
3. Charles Salmon's book on reinforced concrete
4. ACI 318-08 (recently posted in the forum), etc.
If you intend to design your slab for needing bending, go for SAFE instead of ETABS. Membrane - no out-of-plane stiffness; load distribution to your supporting beams will be roughly similar to how you would distribute the loads with 45deg angle for tributary area.
[-] The following 3 users say Thank You to juice for this post:
  • Grunf, Grunf, deadlord
Hello everybody,
Is it possible to define & design Boundary element (size larger than regular wall) in shear wall in etabs?
(02-05-2009, 02:18 PM)aslam Wrote: Hello everybody,
If the intention is to model boundary elements that are thicker than the wall; then the answer is yes, it is possible.
It will be nice if other members of the forum could give aslam some guidance on how to do this; i.e., share your ETABS knowledge.
  • Grunf, Grunf
